Old 01-20-2020, 12:19 PM
N729LS's Avatar
N729LS N729LS is offline
Default Better DynaVibe Results
I have to take exception to saying that some planes cannot be brought to better than 0.1 IPS RMS using a DynaVibe. I used to use an ACES system for balancing, but was gifted a low-end DynaVibe unit.
The basic differences between the cheaper and more expensive DynaVibe units, or the ACES unit, are the balancing software and the convenient memory. Fortunately (?) I am a mechanical engineer, so I wrote my own software in Excel to support the balancing process using the cheaper unit.
Anyway, I guarantee a final value of 0.07 IPS or better, but for most RV's I can get into the 0.03 range! Heck, I've even gotten CJ-6s down to that! And - (Blatant Commercialism Warning) - I offer a discount to EAA members that can come to KFFZ for the balance.
FWIW,
Andy Elliott
Andy Elliott, CFI, RV-8, N303RV
Flight Reviews, Dynamic Prop Balancing
KFFZ, Mesa, AZ
2020 Dues Paid
Old 01-20-2020, 01:42 PM
JDA_BTR JDA_BTR is offline
When a magnitude made sense I made that assumption. The math works well overall. It?s not a recent paper but the theory is sound.
I didn?t say you cant get to less that 0.1 with a dynavibe. I?m at 0.03. With any instrument accuracy at low amplitude is reduced. It just is a little more trial and error at low amplitude in my experience.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 01-20-2020, 05:29 PM
Kuhtenia Kuhtenia is offline
Default DynaVibe-Related Podcast
The crew over at Sonex Flight podcast just posted a new episode specifically related to use of the DynaVibe, including common issues, a long chat with the factory rep, etc.
Definitely recommend a listen - http://sonexflight.com/66/index.html
2020 dues paid
RV-6A
