01-20-2020, 02:01 PM
Dihedral in RV14 (GMU-22)
I'm installing a GMU-22 magnetometer in the left wingtip of my-14. Garmin calls for the GMU-22 to be not only level with regard to incidence but also for dihedral. A couple of questions:
- Anybody know what the dihedral angle is on the -14?
- If you put your magnetometer in the wingtip, how did you make or shim the bracket to allow for the dihedral angle?
Dues Paid for 2020
RV-14
Empennage Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse joined and working on painting interior
01-20-2020, 02:44 PM
Whats wrong with the stock location and bracket?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
01-20-2020, 03:34 PM
Great question.
Too close to heated pitot wiring, landing gear, etc. Garmin recommends wing tip mount (Walt too). Hard IFR on this one.
Dues Paid for 2020
RV-14
01-20-2020, 04:04 PM
Stock location and bracket works great, even with pitot heat and landing gear and unshielded light wiring, etc. Unless you use a pitot heat controller; which I can't see why you would need to.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
https://www.atkinsonurology.com
01-20-2020, 04:15 PM
Ha
If you follow all of garmin recommendations for location you will find the best place to mount the Gmu22 is 10 feet outside the fuselage, flying in close formation with the rest of the plane...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
01-20-2020, 04:19 PM
Not sure what hard IFR is but it works fine at the stock location regardless if you’re in IMC or VMC. Just about everybody uses the stock location for the GMU-22.
Anybody reading the thread use alternate mounting locations?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
01-20-2020, 04:22 PM
Putting it anywhere else is a pain. If I had to put it somewhere else it would be on a shelf in the upper mid fuselage. I don't have a shelf there......
01-20-2020, 05:15 PM
+1 for using the mount
I put mine in the stock location, unregulated GAP26 pitot Heat, Vans (Stein) standard wiring harness, taildragger. Solid as a rock. It has flown several hours of actual IMC including rain and ILS and GPS/LPV to my personal mins of 500? and a bunch of acro too (THAT was in VMC  ). It passed all the interference tests, etc, flawlessly.
BTW - I didn?t even use a twisted pair for my pitot heat wiring. Just ran a ground up to the block on the firewall. GMU-22 didn?t even flinch during the interference test when I turned it on. Biggest reaction was when I moved the stick left and right. Go figure...
Just my opinion, but I have had zero problems using their suggested location. I believe Vans -14 has a Garmin panel and that plane has tons of hours flying all over the place. Not sure, but I bet theirs is in the same place. Scott would know.
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
01-20-2020, 06:03 PM
Originally Posted by bkervaski
Not sure what hard IFR is but it works fine at the stock location regardless if you?re in IMC or VMC. Just about everybody uses the stock location for the GMU-22.
I put mine in the left wingtip. After my friend had continuing issues with his GMU-22 in the stock location, which were resolved by moving it to the wingtip, I decided to follow suit. Vic also told me that he didn?t have problems with the factory plane, but if he was building, he would put it in the wingtip. It was an easy change. I just had Stein make the harness they build for Van?s ~10? instead of 2?. Have not had a problem with it. Another buddy has his in the stock location and has not had problems. Your choice. Do you feel lucky?
MED
140236
N435MD
Miss March 2020
01-20-2020, 06:08 PM
Do you have the info the OP was looking for?
I'm interested .
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
