Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #11
Old 01-16-2020, 12:20 AM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Pricing
Originally Posted by Jvon811 View Post
Maybe someone can clarify this for me, but it appears to me that each function (Attitude, MFD, EIS, CDI) is a different unit. To get all the function of a full EFIS would be $20k+??
It appears so, the Garmin website gives a separate price for each device configuration:
AI $3,995
HSI $4,295
CDI $3,195
MFD $3,195
EIS $5,295
Total $19,975
Presumably cabling, batteries etc. would need to be added.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my low-n-slow Aeroprakt A-22 and the aero club's RV-9A while I build
Old 01-16-2020, 10:17 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Good Morning!
Thank you for all the interest surrounding our newly released GI275! This is an incredibly capable, fully TSO'd instrument with one of largest approved model lists (AML) of any certificated product released by Garmin. It is a truly exciting product that our team of engineers have been working very hard on for quite some time.
The GI275 is approved for a wide range of aircraft ranging from piston singles through twin engine turbine-class aircraft. Many versions of the unit are available for primary and standby functions to include AI, HSI, CDI, Multifunction Display, and EIS. Within each of those categories of instruments there are various options to include choices like synthetic vision with flight path marker, datalink display for traffic and weather, direct-to map functions, cockpit connectivity, and more. Apart from various 3rd party interface compatibility, one of the most exciting features is a wide range of gyro emulation capabilities for many third party autopilots installed in older certified airframes.
Many assumptions are correct that this product was not crafted to target the experimental market. However there are some versions that would be well-served in an experimental airframe. Some examples would be updating to a digital EIS system, adding a round form-factor artificial horizon with features like synthetic vision+flight path marker, or a nice multi-function display with several useful data pages. All within a standard 3 1/8" instrument cutout not requiring large panel modifications.
Given the certification and cost of the GI275, it really shows the value of the G3X Touch system available to the EAB market. With the cost to purchase 2-3 separate electronic indicators, an experimental aircraft owner can have a complete 10.6" G3X Touch flight display system for a similar investment.
Either way, these are great times for advancement of technology in aviation!
Best Regards,
Brad
Garmin G3X Support
g3xpert@garmin.com
Old 01-16-2020, 10:56 AM
climberrn's Avatar
climberrn climberrn is offline
Very impressive instruments. For the certified world that wants to keep the 6 pack layout these seem exceptional.
For the budget minded of us, in the experimental world there are other more capable and cheaper options. It?s always a good thing to have a choice. The more products out there to choose from the better!
Joel
N626JA
RV-7A at CXP
Flying!
Old 01-16-2020, 03:25 PM
RV7ForMe RV7ForMe is offline
Default G5 in round...?
Not sure if it makes sense to garmin but they now already have the outside of the round version of the G5...Can't be that hard to make it work
VAF dues paid for 2020
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 01-18-2020, 01:58 AM
tangocharlie123 tangocharlie123 is offline
Now if only Garmin would make a G5 EIS for experimental.
Old 01-18-2020, 04:12 AM
plehrke's Avatar
plehrke plehrke is offline
I like the drop into retrofitting old panels with these new Garmin instruments but I like the form factor of the Aspen that creates a vertical unit taking place of two steam gauges. I think that works well in certified replacing the traditional 6-pack and experiment new panels. Aspen is just too expensive as well.
Philip
RV-6A - 14+ years, 950+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 01-20-2020, 07:52 AM
If you think you have sticker shock looking those prices, take a look at the pricing for these same units certified for use in Class 2 & 3 airplanes!!!!!
Old 06-05-2020, 10:33 AM
ChuckGant's Avatar
ChuckGant ChuckGant is offline
G3Xpert,
I would like to know if one GI 275 basic can be configured to do multiple functions. I want to only install one 275 and have it act both as a glideslope/CDI for ILS approaches with a GNC 255 NAV/COM and, when not shooting an approach act as a moving map, with all of the associated features, such as nav, traffic, etc. The website and video are not clear on this.
I will have the following equipment installed:
GNC 355
GNC 255A
GTX 345
Thank you,
Chuck
RV7 - N533CV
Based at Holly Springs, MS (M41), near Memphis, TN
The clouds beckon. I must go fly.
