Go Back   VAF Forums > Main > Reviews
Old 01-13-2020, 08:14 PM
cfmcowboy cfmcowboy is offline
Default A review of my EZ-Heat oil sump preheater
I recently installed a sump heating pad system in my RV7A. Works great!
https://www.youtube.com/watch?v=E3t9VgPcUrE
Old 01-14-2020, 05:22 AM
Jpm757 Jpm757 is offline
Love mine.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 01-14-2020, 05:39 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
I would encourage you to do some more research on leaving the heater on or plugged in all the time during the winter. There are plenty of folks here on the forums that have had experience with that. I do not live in the cold country so I can't comment but I still do have a heater pad on my oil sump and only turn it on the morning of my flight.
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
Old 01-14-2020, 06:13 AM
flightlogic's Avatar
Default YUP
My EZ heat has been on the sump three years. That and a space heater (with tilt switch) that sits on the cockpit floor are driven by the switchbox.
When I venture to the loo at around 3 am, the iPhone sends a text to the RV9A. By the time I get to the hangar in the morning (which has hovered around freezing the last few weeks) the oil is at 95F. and the cockpit is 80 degrees.
The RV starts like we are in Florida for the winter. smile
Short of moving to a warmer place for winter (which is not on the option list) this is the best working solution I have found.
I pay too much for the T mobile number since it is on auto monthly billing. That is probably just lazy on my part. I could just add money manually about every 90 days.
Anyway, these sump heaters are simple and reliable. With cowl plugs in, even the cylinders are warmed by convection and heat rising from the sump.
I am reducing start up wear and tear and it is worth the cost and the late night text to the plane!
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 01-14-2020, 06:55 AM
Dean Pichon Dean Pichon is offline
What size or model number did you install? I have an O-360 in my -4 and would like to know what size to buy before I remove the cowling.
Dean
Old 01-14-2020, 06:56 AM
Sam Buchanan's Avatar
been here awhile
I'm not offering a recommendation but only a datapoint because this subject gets some folks all bent out of shape.
I've run a Reiff sump heater on my RV-6 24/7 for four months out of the year for the past 19 years. I have found no issues thus far.....the plane thinks it is spending the winter in Florida.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 01-14-2020, 07:02 AM
bobnoffs bobnoffs is offline
i worry about what happens when one of these ''milk house'' heaters is remotely fired up and because of the cold, well used motor, etc. the fan doesn't start turning. i see it all the time when the temp is in the 20's [f] or lower. it the motor gonna meltdown or is the element gonna superheat with no cooling air blowing across it? i don't think it is a good idea to trust your 100k airplane to a breaker or hi temp auto-off. and have you ever found a mouse nest somewhere that wasn't there yesterday?
but i am a big fan of stick on heaters.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 01-14-2020, 07:26 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
That's a pretty convincing data point, especially for those of us in the humid south
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 01-14-2020, 08:35 AM
Unhappy
Dean
I have the 442 model, it wraps around three sides of the oil sump. They do have specific sized for each model of engine, I know this because I originally bought the continental IO360 pad by mistake! Doh
Old 01-14-2020, 09:53 AM
been here awhile
Let me qualify my situation:
I try to fly the plane at least once a week, but the past year it is more like once every ten days.
It resides in an insulated hangar with a blanket on the cowl and plugs in the inlets.
The oil and all the engine remains above the ambient dewpoint at all times (85-90*F).
This may not be a good idea for colder climes where it wouldn't be possible to keep the entire engine warm with just a sump heater.
Sam Buchanan
RV-6
