Old 01-08-2020, 06:31 PM
scsmith scsmith is offline
Default HI temp Mil-H-83232 hydraulic fluid
After reading some old threads on the subject, I am going to switch over to the higher-temperature hydraulic fluid, Mil-H-83232 (Royco 782).
I am replacing the O-rings in the brake calipers with Viton O-rings, Mil-R-83248-218.
Is there any reason to be concerned that the new hydraulic fluid might not be compatible with the rubber parts in my master cylinders? It is supposedly compatible with Mil-H-5606, even mixable. So I'm not planning to do anything other than drain the system and re-fill.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 01-08-2020, 06:33 PM
BlndRvtr BlndRvtr is offline
Curious, why the changeover?
George
Old 01-08-2020, 06:58 PM
FORANE's Avatar
FORANE FORANE is online now
I switched to 782 from 5606 in both brakes and gear. Brakes were simply drained and refilled; gear was mixed. Have experienced no issues whatsoever after years of use.
Lancair 235/340
RV-9A (2013 - 2016)
Old 01-08-2020, 07:48 PM
rocketbob's Avatar
Mobil 1 synthetic ATF that you can get at Walmart or any parts store has a higher flash point than Royco 782.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-08-2020, 07:57 PM
RV6_flyer's Avatar
Been using it for about 10-years. I have had no issues when I did the same thing you are doing. Have used my MIL-H-83232 on several other airplanes and they were done the same way.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-08-2020, 10:25 PM
George
The primary reason is higher flash point, and self-extinguishing properties. I tend to brake firmly - I try to make every landing stopped in under 1000 ft.
Every now and then you hear of a brake fire.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 01-09-2020, 03:35 AM
KatanaPilot KatanaPilot is offline
Default Matco brakes?
If you have Matco components, reach out to George Happ (also an Aero type) - owner of Matco. tech@matcomfg.com
I asked him that question back in 2017 and he answered "Royco 782 is a version of Mil-H-83282 which is a high flashpoint aircraft hydraulic fluid that is compatible with the Buna nitrile seals we use."
Van's says the same thing on their web store - "Royco 782 is a synthetic fire resistant hydraulic fluid compatible with the seals in the kit brake components."
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
Old 01-09-2020, 08:17 AM
fl-mike's Avatar
fl-mike fl-mike is offline
^^^^ +1
12 years so far with standard components. No issues.
(as a side note, I was thinking the built-in fire extinguishing thread should focus the nozzles on the brakes rather than the engine!)
Mike W
Venice, FL
N164WM
Old 01-09-2020, 09:17 AM
John-G John-G is offline
I too went with a synthetic ATF fluid ... except I chose Amsoil multi-vehicle synthetic ATF because it has a slightly higher flash point of 453?. Have been using it for three years ... without any issues so far.
One nice thing is if I have any issues when away from home that requires adding fluid, Mobil 1 synthetic ATF can be added without causing any compatibility issues .... and it is available most everywhere.
Happy flying,
John
www.dogaviation.com
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 01-09-2020, 10:14 AM
FORANE's Avatar
Looking up flash points for the two,
Mobil one: 420f
Royco: 450f
Close but doesn't appear to be greater.
Lancair 235/340
RV-9A (2013 - 2016)
