Old 01-06-2020, 09:45 AM
raabs raabs is offline
Default Door/Canopy Edge Profile
I?m finishing up the McMaster seals and my next step will be creating the door edge/canopy profile and final gapping.
What are most folks doing on the door edge / canopy profile currently? I searched and read the limited posts but they are a few years old and not a lot there.
Van?s 45 setup doesn?t seem to be desirable. Square edges with slight rounding seems better.
What have you done that you love, fit and look?
Rob Kelly
RV-10 Under Construction
Old 01-06-2020, 10:26 AM
mciaglia mciaglia is offline
Take a look at what I did. I am super happy with the outcome
https://marksfamilyrv10.wordpress.co...ing-the-doors/
Dr. Mark Ciaglia
The Woodlands, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
Old 01-06-2020, 11:24 AM
Mark, Thank you! Your doors look great. You just left the door edges square? Maybe a little easing of the sharp edge?
Thx,
Rob
Rob Kelly
Old 01-06-2020, 11:26 AM
Default edges
I did a square edge with slightly rounded corners...did not like the sharp edge left by a 45...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 01-06-2020, 12:00 PM
Thanks Bob!
Rob Kelly
Old 01-06-2020, 04:30 PM
Electrogunner Electrogunner is offline
Default Gaps
Squared edge with rounded corners here too. I used a multi tool with a flat blade wrapped with 80grit to gap the doors to the frame. Worked great and was very fast. Just change the paper often.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 01-06-2020, 06:37 PM
scsmith scsmith is offline
Please forgive the thread drift, and I'm not building a -10, so I'm not that familiar -- but -- are the door hinges mounted on the exterior surface as shown in your pictures when everything is complete? I thought the door hinges would be recessed in pockets so they were more flush to the outside.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 01-06-2020, 06:41 PM
Kyle Boatright Kyle Boatright is online now
In a stock installation, the hinge halves which mount to the doors are mounted to the inside surface of the doors - only the screw heads are visible from the outside. The hinge halves that attach to the cabin top are external, but they are recessed and flush with the cabin top.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-06-2020, 06:49 PM
You are correct. On my build I decided to use an aftermarket product from Airward. The hinges are a known weak spot in the design of the doors. Airward provides machined reinforcement plates (although they protrude slightly) they make the door attachment solid
Dr. Mark Ciaglia
The Woodlands, TX
