Old 01-02-2020, 08:18 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Exclamation Avoid electrical tape
Originally Posted by RV8JD View Post
Thanks for this, I just learned something; Vans says to not use electrical tape on the canopy. I wouldn't have thought of that, but good to know about it.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my low-n-slow Aeroprakt A-22 and the aero club's RV-9A while I build
Old 01-02-2020, 10:25 PM
Thermos's Avatar
Thermos Thermos is offline
It looks like Van's used vinyl (electrical?) tape when masking the RV-14 canopy in their "Canopy Fiberglass Fairing: How-To Video Series" -
https://www.vansaircraft.com/faq/can...-video-series/
Maybe Scott/rvbuilder2002 can chime in here and clarify what was being used.
Dave
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
Old 01-02-2020, 10:31 PM
Wunderon's Avatar
Wunderon Wunderon is offline
the electrical tape warning refers to Lexan, not acrylic. It’s ok to use a good quality electrical tape to mask the canopy for fiberglass layup, but I wouldn’t leave it on any longer than necesssry.
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
Old 01-03-2020, 09:33 AM
PropMan PropMan is offline
Plexus has Always worked for me.
https://www.aircraftspruce.com/catal...ges/plexus.php
Frank
RV6-N164FJ sold sadly
Legal Eagle w/Verner 3VW
Rans S7s
RV4- in progress
Old 01-03-2020, 10:39 AM
rvbuilder2002's Avatar
Dave
Originally Posted by Wunderon View Post
the electrical tape warning refers to Lexan, not acrylic. It?s ok to use a good quality electrical tape to mask the canopy for fiberglass layup, but I wouldn?t leave it on any longer than necesssry.
Dave already provided the correct answer.
Scott McDaniels
Hubbard, Oregon
Old 01-03-2020, 03:57 PM
BillL BillL is offline
Default Tip Lens Not the same material.
Getting OFF TOPIC - the tip lenses are vinyl (or something) and WILL melt with alcohol. I was polishing one and decided to test a piece of scrap first, yep isopropyl alcohol will soften and mar the tip lens
Bill
RV-7
Lord Kelvin:
Old 01-04-2020, 09:09 AM
laz laz is offline
I used 3M Adhesive remover. It nose not attack the plexiglass. Use it very sparingly and test a small area, of course. This stuff is designed to remove adhesive from paint without attacking the paint. I removed spots from my RV 8 canopy over 2 years ago and have never seen any marks left by the remover.
The stuff is expensive but a can will last you years. It is excellent fro removing all kinds of stuff from paint without leaving a mark.
Old 01-04-2020, 09:24 PM
DickDe DickDe is offline
Default Reply to Jeff W.
Bushing part Number...there is none. Bushings were cut out of neoprene gas line material used in chainsaw engines. I also did the same with left over nylon brake line material from Van's brake kit. A small tool I made out of 2 scrap pieces of plexiglas and a single edge razor blade. Two pieces of plexi were pop riveted together flat & shimmed apart at the edges to give the targeted bushing height. One piece of plexi had a hole the same diameter of the gas line material drilled in it. The shims provided the control of the length of multiple bushings. The razor blade slipped between the two pieces of plexi to cut the gas line to form a bushing which was held in the hole.
I made a few of these devices shimmed differently to provide all the bushings I needed and I cut 20 to 30 at a time. The idea was to capture the canopy between two pieces of aluminum and the grip of the fastener would grip the bushing and NOT the canopy but the bushing was only .005" to .010 Thicker than the canopy. The RV6 canopy was fairly consistent in thickness but the RV8 had a narrower canopy which is very thick at the aft end so bushings of various sizes had to be cut. All holes were countersunk as well for the dimpled aluminum strips and fasteners. This whole process costs almost nothing but there is some added labor which is manageable. I never considered Sikaflex as my first build was before I heard of the stuff (1990's) and I did not like Van's pop rivets on the bare canopy but a similar process was used in some Cessna windscreens I did.
Dick DeCramer
Faribault, MN
