Old 01-02-2020, 05:13 PM
rwtalbot rwtalbot is offline
Default Removing the rotor?
How do you remove the magnet/rotor assembly from the shaft? Is it a press fit?
Richard
Richard Talbot
RV-7A
Sydney, Australia
Old 01-02-2020, 08:46 PM
Richard
The one i used was from a slick mag. I tried to machine it off with poor results. Then i realized it is cast on (maybe aluminum) with the magnets embedded in the casting. I ended up just melting it off with a propane torch. Then there were two brass rivets that I drilled out.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 01-02-2020, 08:49 PM
Where are you guys mounting your coils? In the upper plenum area would make for short plug wires (for one set), plus it is pretty cool during flight. On the other hand, on the firewall gets them away from the vibration.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 01-02-2020, 09:15 PM
lr172 lr172 is offline
On the 6, I put the coil on the firewall. Not enough room to put on top of the engine with the coil type I had (top facing posts). On the 10, I put one on top of the engine and the other on top of the engine mount. The 10 cowl area has a lot more room to work with though.
Larry
Old 01-02-2020, 10:00 PM
Larry
Thanks for the input. I think i am going to mount them to the engine mount on angle atrached via cushion clamps. I could always move thrm to the firewall later, but this looks to be the most modular and least intrusive.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 01-03-2020, 12:37 AM
Thanks Colin, I had issues with the first one too. On the second one I found an angle grinder removed most of it. I then carefully removed the remainder with the lathe.
Richard Talbot
RV-7A
Sydney, Australia
Old 01-03-2020, 02:06 PM
The torch ended up working great. Took just a couple minutes and everything came off clean.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 01-03-2020, 05:26 PM
rocketbob's Avatar
I'm happy to repost my drawing in inches. However, my setup is yet untested. Also, I made a few minor tweaks that aren't on the drawing. I made the o-ring grooves slightly deeper and made the engine-side bearing press fit and the aft bearing slip-fit.
Yes that would be great.
Would like a drawing of the shaft as well. I think it would be ok to make it out of 4140 or 8620 steel.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-08-2020, 08:08 PM
Bob,
Sorry for the delay. Here is my housing drawing in inches. I don't have a detail drawing of the shaft since I repurposed one from a slick mag.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 01-14-2020, 03:38 AM
Bob,
Interesting, so you have an O-ring seal at the top or is that grove for bearing retention?
How are you attaching the gear to the shaft? Loctite 638 might be an option with interference fit, or is there still room for a grub screw? There must be a secure solution involving a minimum of machining. It looks like Dan may have used grub screws.
Richard Talbot
RV-7A
Sydney, Australia
