12-31-2019, 05:11 AM
IO-360 Fuel Injection
Hi Guys
I wonder if someone can help. I have an IO-360 Parallel valve 180Hp w/CS prop. At WOT full rich I only get 13.8-14 gph fuel flow which seems low based on some reading I have done.
What should I expect to see and whom would you guys recommend to send my fuel servo in to for a IRAN check and service. I am based in NC.
Bryan
12-31-2019, 05:38 AM
Hi Bryan,
I typically see 16.5-17.0 GPH on take-off with the same engine/prop you describe. Your flow does sound low. Is your fuel flow sensor well calibrated? I assume you are seeing that flow at a low altitude (<1500 feet)?
I have an Airflow Performance injection system. I have had it serviced only once by Don Rivera at Airflow Performance. Very good service from Don.
Good luck,
Dean
12-31-2019, 05:50 AM
Fuel Flow
Hi Dean
Fuel flow in gph reading is within one gallon over 4 hrs of flying. Our field elevation is 740ft.
Bryan
12-31-2019, 06:18 AM
I would suggest you call Airflow Performance. They are located in Spartanburg, SC. Your fuel flow sounds low, but you should do some EGT tests before sending in the servo. Don at Airflow Performance can help you with what to look for.
Mark Hansen
Indianapolis, IN
RV-7A N896PS
Flying
12-31-2019, 07:21 AM
Wilco - thanks Guys
12-31-2019, 07:40 AM
Agreed, that sounds low by 2.5-3 gph.
12-31-2019, 07:42 AM
Brian---youre at Gold Hil-----Kahuna and Ron Schreck are both there and could possibly help.
Don Rivera is an easy flight to Spartanburg---
Tom
Ridgeland, SC
12-31-2019, 08:49 AM
Check the simple stuff first. Make sure you?re hitting the stops for throttle and mixture.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
12-31-2019, 08:54 AM
Also, make sure your fuel flow reading is calibrated and reading correctly.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
12-31-2019, 09:48 AM
Bryan,
What is you RPM and Manifold Pressure when you see those low fuel flow readings?
