Old 12-31-2019, 05:11 AM
bryannortje bryannortje is offline
Default IO-360 Fuel Injection
Hi Guys
I wonder if someone can help. I have an IO-360 Parallel valve 180Hp w/CS prop. At WOT full rich I only get 13.8-14 gph fuel flow which seems low based on some reading I have done.
What should I expect to see and whom would you guys recommend to send my fuel servo in to for a IRAN check and service. I am based in NC.
Bryan
Old 12-31-2019, 05:38 AM
Dean Pichon Dean Pichon is offline
Hi Bryan,
I typically see 16.5-17.0 GPH on take-off with the same engine/prop you describe. Your flow does sound low. Is your fuel flow sensor well calibrated? I assume you are seeing that flow at a low altitude (<1500 feet)?
I have an Airflow Performance injection system. I have had it serviced only once by Don Rivera at Airflow Performance. Very good service from Don.
Good luck,
Dean
Old 12-31-2019, 05:50 AM
Default Fuel Flow
Hi Dean
Fuel flow in gph reading is within one gallon over 4 hrs of flying. Our field elevation is 740ft.
Bryan
Old 12-31-2019, 06:18 AM
Mark H's Avatar
Mark H Mark H is offline
I would suggest you call Airflow Performance. They are located in Spartanburg, SC. Your fuel flow sounds low, but you should do some EGT tests before sending in the servo. Don at Airflow Performance can help you with what to look for.
Mark Hansen
Indianapolis, IN
RV-7A N896PS
Flying
Old 12-31-2019, 07:21 AM
Wilco - thanks Guys
Old 12-31-2019, 07:40 AM
airguy's Avatar
airguy airguy is offline
Agreed, that sounds low by 2.5-3 gph.
Old 12-31-2019, 07:42 AM
Brian---youre at Gold Hil-----Kahuna and Ron Schreck are both there and could possibly help.
Don Rivera is an easy flight to Spartanburg---
Tom
Ridgeland, SC
Old 12-31-2019, 08:49 AM
JonJay's Avatar
JonJay JonJay is offline
Check the simple stuff first. Make sure you?re hitting the stops for throttle and mixture.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 12-31-2019, 08:54 AM
Bavafa Bavafa is offline
Also, make sure your fuel flow reading is calibrated and reading correctly.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 12-31-2019, 09:48 AM
Full Throttle Full Throttle is offline
Bryan,
What is you RPM and Manifold Pressure when you see those low fuel flow readings?
