Old 12-30-2019, 11:13 AM
mdmba mdmba is offline
Default Hartzel composite prop
I have the Hartzell composite prop on my RV 8..just wondering if one can put one on the IO-390 for 14A?
Old 12-30-2019, 02:51 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Looks like it. See this:
https://www.vansaircraft.com/order-a...er-order-form/
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 12-30-2019, 03:02 PM
Northernliving Northernliving is offline
Originally Posted by RV8JD View Post
For some reason they only have it listed for the 7A/14A, yet okay for the 8 and 8A.
Off topic - did you see the price of the new 3 Blade Raptor? $20,100! I was holding for a while to see what the pricing would be like and I'm glad that I moved on.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 12-30-2019, 03:34 PM
RV8JD's Avatar
Because it's a 74" prop. From the same link:
"Propeller size note:
The 74" blade diameter propellers are applicable to all "A" model RVs plus the RV-8.
The 72" blade diameter propellers are recommended for all tailwheel aircraft (except the RV-8 as noted above) to ensure adaquate ground clearance for those models."
Carl N.
(Pic 1),(Pic 2)
(Pic)
