  #41
Old 12-24-2019, 07:33 AM
gereed75 gereed75 is offline
As another option, I have a big steel sewer grate on the taxi way just outside my hangar. Park the tailwheel on it and Tie down with two cargo straps. Works “grate” because there are multiple places to attach the hooks.
Use it routinely when solo for doing post maintenance run-ups for leak checks and timing checks.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
Old 12-29-2019, 12:41 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default tying down tailwheel
Here's how I did it and it worked fine. The strap is about 2" wide. Tied to the frame under the car, and used the wheel to hold the strap down. The part of the strap between the wheel and the frame didn't even get tight.
Many thanks for the hints and suggestions!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-29-2019, 01:01 AM
DeeCee 57's Avatar
DeeCee 57 DeeCee 57 is offline
did ya measure the thrust? How much?
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
Old 12-29-2019, 01:45 AM
rv8ch's Avatar
Default Thrust measurement
Not yet - I want to do some more tests to make sure that I can actually produce full power on the ground before the tests. Going to make a shroud today to improve cooling during the ground run. In only 2-3 mins #3 got up to 341F, so I'm sure a full power thrust test would get to 400F without a shroud.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-29-2019, 02:09 AM
DeeCee 57's Avatar
just had a look at my data... YLL pulled factored 345.1kg @ 2570 static RPM, config see below.
Be sure your weight on strap is good enough
DC aka Dan
Old 12-29-2019, 10:25 AM
Discus2b Discus2b is offline
Nothing like sandblasting the car....
R
Old 12-29-2019, 11:18 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
My RV-8 will raise the tail at power if the flaps are extended but if not I can go full power with stick all the way back and it'll stay set. Maybe I need more power(bigger engine)?
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
