  #11
Old 12-20-2019, 02:54 PM
9GT's Avatar
9GT 9GT is offline
Had a similiar incident with my building buddy when I was safety pilot for him while he practiced his IA's in his Cozy MKIV. Engine lost power as we were climbing out and then the engine started shaking so bad we thought a prop blade departed the hub on his 3 blade MT. Cylinder #4 went completely dead pretty quickly. Long story short, when I started pulling plugs, # 4 was wet and all the others were coated with soot. Started pulling injectors and found #4 with a particle of some substance blocking the orifice. Poked it out and cleaned all the injectors in Hoppe's #9. All good. Hope your problem is as EZ to fix.
David C.
Howell, MI
Old 12-21-2019, 10:53 AM
rcoleman-10 rcoleman-10 is offline
Default RV-10 Engine data review
I use cirrusreports.com
it uploads lots of data from your SD card for every flight.
Good visualization of engine parameters.
If you have any questions feel free to PM anytime.
Ron
3T5
N145RV
Old 12-25-2019, 10:32 PM
Thor RV10 Thor RV10 is offline
I don?t know why you wouldn?t want to use Savvy.
Old 01-08-2020, 04:46 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
So what happened here....I never got an email, anyone else know how this guy got on?
David Brown
Old 01-08-2020, 08:59 AM
Lynnb's Avatar
Lynnb Lynnb is offline
The data didn't lead to it, but a quick look by an A&P and they think a stuck exhaust valve might have been the culpret.
RV-10 in Process
