04-10-2018, 01:24 PM
3-blade propeller MT
question I have in mind of monatre on my RV7 a 3-blade MT propeller. do you know how it works with RV7?
04-10-2018, 01:42 PM
Senior Curmudgeon
Welcome to VAF
Agostino, welcome to VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
04-10-2018, 04:23 PM
Email sent
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
04-10-2018, 06:37 PM
Super Moderator
I had one on my rv-7A and really liked it.
Vic
 Vic Syracuse
www.Baselegaviation.com
04-10-2018, 07:51 PM
I installed a new IO-360M1B and MT 3 blade from Vans on my -7, with the new 59B blades. I am VERY pleased with this combination after 100 hours. Takeoff and climb performance is outstanding, and I am dead even with my hanger partners 180/CS Hartzel RV8 in climb and cruise.The MT was incredibly smooth BEFORE I had it balanced. Weight and balance numbers came in right where I had hoped. A little pricier than the Hartzel, but prop includes a beautiful painted & installed spinner assembly. Literally bolt the prop on and you're done. Have flown in rain, soft fields and frozen lakes with no blade erosion whatsoever. Also using the MT governor supplied with Vans FWF kit, dead on at 2700 rpm/no adjustment was required. 12 week lead time on delivery from Germany and the prop is shipped to a local dealer for assembly and delivery.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
04-11-2018, 11:02 AM
thanks to all and I apologize for the question a bit out of place.
sorry...
04-12-2018, 08:07 AM
Very happy with mine
In my case I can out climb but have lower top speed than other RV7 aircraft I have flown with. This is in line with much of what I read on this forum as well.
We are taking a knot possibly two at low alt so the difference is rather small. I also just like the look of a 3 blade
If anything, the three items I would suggest you consider are:
1) I feel the 3 blade composite reduces vibration a bit over metal 2 blade
2) The light weight of the prop and modern starters shifts the CG weight back enough where you will hit aft CG limits before gross weight unless dealt with during the build.
3) It will be harder to remove the cowl for service
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
12-20-2019, 01:04 PM
MT Prop
I am currently building an RV7A with the angle valve IO-360. I am considering a Sam James Cowl and Ram Air kit. Does anyone know if the MT 3 blade prop would require an extended hub for this configuration?
Thanks much
12-20-2019, 04:07 PM
Just tell MT your engine, induction type and cowling and they will send you the correct spinner and extended hub.
That?s what they did for my combination:
Lyc-IO360-M1B, horizontal, Sam James long cowl.
You can contact Eric Greindl. Eric.greindl@REMOVETHISmt-propeller.com
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017/2018/2019. . . Done.
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
12-20-2019, 04:10 PM
You might give McFarlane Aviation a call. They are the new master distributor of MT props in the U.S. I had the good fortune to speak with Dave McFarlane himself at length regarding the MT prop. Mr. McFarlane flies an MT on his personal aircraft as well. His knowledge and personal experience gave me loads of reasons to go with MT, so I did. The reasons extend to go MT go far beyond flight performance.
My guess is that we'll see him advertising on this site one of these days.
Fred
Dues Paid for 2020
RV-14
Empennage Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse joined and working on painting interior
