Originally Posted by Toobuilder
The last few posts have me confused. The 430, GRT WS and Digiflight II I've been flying for years provided flawless altitude capture from the EFIS. Once the AP was engaged, all commands were from the legacy WS screen. Is the need to drive vertical guidance from the AP head a Vision 385 specific issue? Seems like a step back if so.
Micheal, Does your Digiflight II have vertical steering? The one I had didn't. If I remember correctly it was an option.
My initial setup was the same as yours, my AP had altitude hold and vertical rate, but no altitude input or capture from the EFIS that I remember. At the time it was easier to just fly off the AP head with guidance from the non-WAAS 430.
The airplane has returned after 12 years and I've upgraded the AP to the TruTrak Vizion with altitude steering. All else is the same for the time being, upgrade coming soon. Now I use the EFIS to control the AP and I can vertically steer the AP through the EFIS, but only after it captures the altitude in level flight. Like in the other posts, if the AP is engaged during a climb I have to disengage at the programmed altitude, level off and re-engage the AP. Once vertically captured I can dial in altitudes or have it follow a synthetic approach.
I engage the AP by pushing the left "Mode" button. It comes up GPSS and the vertical side will display the vertical speed if engaged in a climb or VS if I'm level. At SnF I asked about not capturing the preset altitude and the guy at TT said you just push this and that and it works. Sounded easy and I should have wrote it down... I tried it and so many other combinations that I don't remember what the original one was.
I just checked and the AP does gather baro info from the EFIS. Although it takes more than a few seconds scroll to the new elevation. The EFIS preset altitude does not show up in the Sel Alt window. Maybe that is supposed to happen and that's why my AP isn't capturing the EFIS preset altitude from a climb engagement.
Regards,
Dave
