Old 12-16-2019, 02:58 AM
SegevFly SegevFly is offline
Default Oil in the induction system.. Ideas?!
Hi Guys,
Calling on engine people!
We found 3 of 4 cylinders were wet around the inlet valve guide in an IO360 after pouring a not-insignificant amount of oil out of the main engine intake tube (before it branches off to individual cylinders).
Pulled all 4 jugs off and sent them to the a local engine shop.
They all come back with pretty paint, 4 new pistons, few new valves springs, new exhaust valve, new rings and a big $$$ bill. They say we did not replace any of the intake guides as they'd already been done once, can't do again and they looked fine and within the Lycoming tolerance.
We put all the jugs back on. We go flying. 2 hours later, check intake and it's got a puddle of oil in it again.
The engine shop claims it cannot be the inlet valve guides leaking as any oil would be sucked into the cylinder and burnt. There is no way it can be in the intake.
We are now 11 hours after the engine overhaul, been running high power settings for a long period to brake-in the engine per their recommendation, with no sign of improvement.
Interestingly enough, we only lost 0.5qt of oil in these 11 hours..
Attached pictures of the ground below the aircraft, as well as the intake tube
https://ibb.co/ryN7Hyb
https://ibb.co/2tCNmkf
https://ibb.co/dKm3k3N
https://ibb.co/zNZZZss
https://ibb.co/7pY5jZ8
https://ibb.co/2vFYR2q
Open to suggestings and ideas
Many thanks,
Old 12-16-2019, 04:32 AM
FredMagare FredMagare is offline
I'm not sure if this is true.... I'm thinking that there will be oil in the valve covers that can seep past the valve guide after shut down and into the intake. In any case, if it's not causing a problem with power, I'd recommend placing trays under the leaks and keep flying until you're ready to overhaul the engine.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 12-16-2019, 01:35 PM
newt's Avatar
newt newt is offline
Is the main oil seal on the crank leaking, with the oil finding its way into the induction system through the air filter/throttle body?
Your photos don't include anything about the general condition of the engine installation, so I'm just speculating...
[ Paid up on 3 Feb 2020 ]
RV-6 VH-SOL
Old 12-16-2019, 07:02 PM
kkmarshall kkmarshall is offline
A friend of mine had oil pooling in the same place and it turned out to be a tiny crack in the sump letting oil in the sump migrate into the intake area. Just FYI
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
Old 12-16-2019, 08:27 PM
isosceles isosceles is offline
Default Sniffle valve?
Have you got a sniffle valve installed on that engine?
Old 12-17-2019, 06:16 PM
pa38112 pa38112 is offline
I do not understand how it is getting on the ground if the oil is in the intake tube. Is it coming out of the throttle body?
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 12-17-2019, 07:58 PM
Reformed SeaSnake Reformed SeaSnake is offline
+1
That fits what you?re reporting especially if the engine has a sniffle valve and the oil on the floor is right beneath it. Also, you?d see less oil loss at the high power settings you?ve been running where the pressure in the sump and the intake are similar.
Jason Rood
Beaverton Oregon | RV-8A, Very slow QB
No Pithy quote here; just the sincere hope that your day ends better then it began
Old 12-18-2019, 02:24 AM
Hi All,
Firstly - thank you for your time looking into my engine issues.
The engine is installed in a Pitts S1S and is a vertical intake. Therefore no sniffer valve, nevertheless, the oil just simply run out of the throttle body, then into the floor via a small drain hole which is located in our air intake.
Based on the comments and suggestions provided, I am going to try and locate another sump, install it on our aircraft and fly to identify if it is the issue, if it does, I will get a new one from Superior or Lycoming
While perhaps costly, I am unable to determine what the oil is coming from otherwise..
I attached some additional pictures for your information, and I promise to let you know how I go!
https://ibb.co/syt2KgJ
https://ibb.co/mHH9Vkz
https://ibb.co/CQ8JjHs
https://ibb.co/nwQ9Xqy
https://ibb.co/hBvxC0c
https://ibb.co/jwgmRH1
Thank you again,
Old 12-19-2019, 08:28 PM
Boyd Birchler Boyd Birchler is offline
At idle and low power the intake has a vacuum, the rocker box has a good bit of oil in it. Since the intake guides end opposite the end in the rocker box is in a vacuum, some oil will be sucked into the intake port. Most of this oil will go into the cylinder and get burned, the rest drains into the intake system.
On horizontal induction systems there is a one way valve in the bottom of the intake plenum to let this oil and any residual percolated injector fuel drain out. It is called a sniffle valve.
Old 12-19-2019, 11:11 PM
scsmith scsmith is offline
my vote would be a crack in the sump somewhere, or a bad seal somewhere that keeps the sump separate from the intake tubes.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
