Old 12-11-2019, 04:51 PM
boom3's Avatar
boom3 boom3 is offline
Default B&C Starter Solenoid
Has anyone found a direct replacement for the B&C starter solenoid? I really don't want to send the whole thing back to B&C.
I've been having intermittent starting issues on my IO-360. (just clunks no cranking, it's the Van's solenoid that I can hear on the firewall).
I have a relatively new battery, confirmed good electrical connections, and even replaced the Van's starter relay.
I'm guessing it's the starter or solenoid but thought I'd start with the solenoid portion.
Thanks!
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 12-11-2019, 08:52 PM
hgerhardt's Avatar
Why don't you unbolt the solenoid so that you can see the plunger end of it? Then you can compare it to an off-the-shelf unit on a site like rockauto.com which has nice illustrations of their parts.
Wouldn't it be funny if they used the same Ford PMGR solenoid as Sky-Tec does?
Old 12-12-2019, 04:38 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Default Welcome to the club...
...except mine was a Plane Power 149-LS/PM whatever...
Looking at the B&C website, it appears that the starter solenoid is the same as the Ford PMGR unit.
It's out of a 2005 Ford Crown Vic. Borg Warner is the "original" unit - many knock offs available, tho. I think I paid ~$36 for it from Advanced Autoparts.
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 12-12-2019, 07:38 PM
isosceles isosceles is offline
Take it to a local starter shop. They will replace the solenoid. Rumors are it's just a repurposed Hitachi 1.4kW starter.
Old 12-13-2019, 08:45 PM
boom3's Avatar
Well today I bought a PGMR solenoid from Napa just in case it was the correct one. When I took the solenoid off I found it was quite a bit different. The plunger is obviously different but there is also what looks to be a heavy duty return spring. The spring obviously slides right out, but the solenoid has to have the holes for it.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 12-14-2019, 07:02 AM
bjdecker's Avatar
Time for a trip to soundstarter in Tacoma
http://soundstarterandalternator.com/
Play dumb tho -- tell them it's from a kit built off-road vehicle
Brian Decker
1986 Mooney 205SE
1980 Mooney 231
