Old 12-10-2019, 03:48 PM
RViator60 RViator60 is offline
Default Aileron Trim kit
Does anyone have an opinion/experience with the aileron trim option for the RV-14?
Marty Guinn
Based at KSUT, Southport, NC
- 1973 PA28-180 (N55087)
RV14A Build
- Started Sep19, Aft Fuse complete
- Wings and fuel tanks completed,
- IO390 ordered (Oct20 deliv)
- Hartzell 2-blade composite delivered.
- Currently working on fuselage
https://eaabuilderslog.org/?s=MartysRV14A
Old 12-10-2019, 04:06 PM
bkervaski's Avatar
bkervaski bkervaski is offline
It's easy to install and worth it
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 12-10-2019, 05:10 PM
Bavafa Bavafa is offline
On the 14/14A, electric trim is the only option and it is well worth the $ and little effort it takes to install it. It is easier to install it during the build then later on.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 12-10-2019, 05:32 PM
caapt caapt is offline
Default mount in right wing
If you mount your magnetometer in left wing as per plans, better to mount trim in right wing. Also, the left harness is pretty full going through routing bushings. Not a problem routing through the right wing. Be careful about inverting the install.
14A Wing Complete!
Tail Complete
Fuse Complete
Engine installed
Wing Mounted
Inspected and certified 1-31-20
First Flight 3-25-20
Old 12-11-2019, 11:06 AM
Logan Logan is offline
Another vote for the aileron trim. It is very handy and relatively easy to install, except for those tiny pins! Had some trouble getting those to sit correctly.
Logan Dent
RV-14A Complete!
Airworthiness cert issued June 27, 2018
Old 12-11-2019, 01:00 PM
TASEsq TASEsq is offline
In fact, for the -14 OP38 says builders MUST put it in the right wing. For the -10 it can be left or right.
Does anyone know if this is just because the AHRS mounting plate gets in the way on the -14? I.e. if you mounted the magnetometer somewhere else (and the AHRS behind the panel) you could indeed use the left wing?
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Aug 2021
Old 12-11-2019, 01:18 PM
Nova RV Nova RV is online now
The wing wiring harness also has the wires ready for you in the right wing. Aileron trim kit is a must have for the 14 unless you always fly with 2 equal weight people and tanks perfectly balanced.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 12-15-2019, 08:19 PM
Jake14 Jake14 is offline
anyone using the manual aileron trim kit? $46 vs $300 for the electric and seemingly easier install
RV-14A flying 410 hrs
Old 12-16-2019, 12:03 AM
rvbuilder2002's Avatar
The manual trim kit is for the RV-6, 7, and 9 only.
They have a different type of control column design than the RV-14.
Scott McDaniels
Hubbard, Oregon
Old 12-16-2019, 12:35 PM
Wingit Wingit is offline
Default Elevator trim
Is there a way to do manual elevator trim?
