12-09-2019, 02:11 PM
Pre-dimpled nutplates
I've bought dimpled nutplates, in the same sizes that Van's use in many applications. It gives me a choice, and if my memory serves me correctly it's the same part number with a "K" at the end.
RV-9, Tail Feathers done, Wings almost done.
12-09-2019, 03:05 PM
Dimpled nutplates
The glaring question I have to ask is
why not just get dimpled nutplates?
12-09-2019, 03:22 PM
Nut plate
I am really not sure why this is even an issue; it takes like five seconds to dimple the mounting ears on a nut plate with a hand squeezer.
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
12-09-2019, 03:25 PM
Agree . . .
Or just use NAS rivets. A flush head can install a nut plate in .025 material just fine. And much less time investment in the entire process.
Bill
RV-7
Lord Kelvin:
12-09-2019, 05:23 PM
IIRC the part number with the K suffix is manufactured to accept a dimple nested into the center hole - the threaded one - for use with flat head screws. The discussion here concerns dimpled ?ears?, the ones usually riveted on.
12-09-2019, 05:29 PM
There are dimpled nutplates available from Van?s, they are supplied in the RV-12 kits. They have a ?D? suffix (i.e. K1000-08D). Not sure what additional sizes are available, as others have said, pretty quick to just dimple standard nutplates or use NAS rivets.
Bob
RV-10 builder x2
RV-7A under construction
EAA Tech Counselor
12-09-2019, 06:21 PM
The part number for some of the ones I bought were MS21047L06K, and these certainly had the dimpled ears for countersunk rivets. The part description is "6-32 THREAD, SELF-LOCKING NUTPLATE, TWO LUG, LOW HEIGHT, CADMIUM PLATED CARBON STEEL, 450 DEG F, WITH DRY-FILM LUBE, COUNTERSUNK RIVET HOLES
ALT. PART NUMBER: NAS680A06K"
12-09-2019, 07:02 PM
A seasoned builder saw a dimpled nutplate on my project and asked why in the world I would do that. Told me about NAS1097 rivets. I started using them and never looked back.
RV-7:
Empennage complete!
Wings in progress
12-10-2019, 07:11 AM
Dang, looks like the RV-12 skin is only ~0.018, at least the piece I measured, which was the rudder. Steps away... Ok, got about 0.023 on the VS where the 18 nutplates were, not sure if that is 0.025 nominal?
Bobby Steinmetz
Van Buren TWP, MI
Student Pilot, Mechanical Engineer
RV-12is Empennage Kit, Fuse Kit, #121228
N781PT Reserved
Donated 2020
12-10-2019, 04:09 PM
Yes .025 as stamped on the sheets. It may work for thinner, you should try it before committing to its use.
I like the NAS as you can just countersink with the deburring tool. I do 7 rounds and it is done. YMMV as always.
Bill
RV-7
Lord Kelvin:
