12-02-2019, 08:18 AM
Igniton wire pass through seals
I am working on my baffles and need some ignition wire pass through seals for two wires. Spruce has the slick brand for 28$ each which is ridiculous. I found some for 7$ but the wire holes are 8mm, is this to large? I plan on running Pmags but have not been able to find the wire diameter. Also if anyone has another source for these it would be appreciated.
12-02-2019, 08:41 AM
I'm running PMags with autoplugs in my -4. The ignition harness provided with the PMags is 8mm dia wire.
Good luck.
Dean
12-02-2019, 08:47 AM
You might consider just using rubber grommets. Works for me.
Erich
12-02-2019, 09:20 AM
Too much $$$
You could always buy 2 of the three hole variant, and use the extra hole for cables, wiring, or just seal it off..
https://www.aircraftspruce.com/catal...ebaffle376.php
I think, but not certain, that some plug wires are 8mm in dia. Just assemble the seals and drill 'em to the right size.
Cheers!
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
12-02-2019, 10:26 AM
Thanks, I have plenty of information to work with now.
12-02-2019, 06:55 PM
Don?t worry about it. If too small, grab your drill and bit. If too large, RTV is your friend when baffling....
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
12-02-2019, 07:07 PM
If the holes are too small, and mine were, just drill them out.
Grommets are a great idea but make it difficult to slide the head of the of the wire through the small hole.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
12-03-2019, 07:13 AM
I?m using pMags and you can find the wire pass throughs at www.bambas.com
Karl Bambas
1954 1st solo
1964 Mooney Statesman, 1979 C-172, 1948 Globe Swift (all sold)
RV-7 "Dream Weaver" N50KB
Empennage arrived 10/14
QB Wings & Fuselage arrived 06/15
Finish & FF kits arrived 11/15
Dual screen Garmin G3X instruments and harness delivered by Stein 01/16
First flight June 13th 2018
2020 Dues Paid
Builders Log
Family Blog
12-03-2019, 11:39 PM
Used the slick ones from spruce with my PMags. Touched the holes up with a reamer. Works great.
Joel
N626JA
RV-7A at CXP
Flying!
