Old 11-24-2019, 08:53 AM
unfluencer
Default What did you do with your RV this weekend. (Nov 23-24, 2019)
...getting it started. v/r,dr
Doug Reeves (your host)
  • Typed in the EMB-505 (Phenom 300). Available for contract work. (flying resume).
  • Part time: Supporting Crew Member CAE EMB-505 Level D Sim @ KDFW.
Old 11-24-2019, 09:41 AM
plehrke's Avatar
plehrke plehrke is offline
Did my Biennial flight review then flew another hour to celebrate.
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 11-24-2019, 07:28 PM
gfb gfb is offline
Dropped her off to get painted. I now need to cmoe up with something to do with myself till Jan 20th
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 11-24-2019, 07:38 PM
Tom023 Tom023 is offline
Flew off the final Phase 1 hours. Total time = 43.4 !
RV14A #140083
Flying! 8/12/19
2020 Donation
Old 11-25-2019, 07:28 AM
N546RV's Avatar
N546RV N546RV is offline
Hung the vertical stab. Was all ready for yesterday to end with me riveting the splice plate on and having it attached by just bolts, only to find edge distance issues with the rivet holes at the end of the forward spar.
So instead I ended the day with an email to the mothership. Pretty sure I can just add another row of rivets here and be OK (I found a post here where someone said they got this exact suggestion), but given the part of the structure we're talking about, I want to hear directly from home base on this one.
Next up: putting those flappy things on the back and getting them connected to the waggly thing in the cockpit.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 11-25-2019, 07:36 AM
FlyingBanker's Avatar
FlyingBanker FlyingBanker is offline
Got it back from condition inspection on Friday (thanks Vic Syracuse!) and flew it home after a brief stopover at 6A2 to check on the status of my instrument panel upgrade order. On Sunday after church, flew with the bride to Barnstormers Grill at Alexander Memorial - GA2 - formerly Peach State Aerodrome for Sunday lunch buffet. Beautiful fall weekend in the south.
Jim Bedsole
N62MG - RV-6A "Promises" - bought flying
Dues Paid
Old 11-25-2019, 07:52 AM
swjohnsey swjohnsey is offline
Flew the newly acquired RV-4 from Bishop, TX (07R) to Fredericksburg (T82) to check out the Hanger Hotel and eat breakfast at the diner then on to Uvalde (UVA) topped off and back to Bishop. I was trueing out around 170 kts at around 8,000 ft at 2400 rpm and 21 in burning about 9.5 gph.
Old 11-25-2019, 08:41 PM
hpdmp3486 hpdmp3486 is offline
Finally cut the two wing spars bolt that were found loose on inspection. The washers were not put on so you could never tighten them to torque specs. I have the RV9A so getting to them was difficult, forming a wrench to fit into the opening was a task. We got the right side off but the left side nut was rounded. Had to use a Dremel with an extension, a few carbide bits, two hours of laying in a difficult position, and finally got the nut off. New bolt, with a washer, and nut tightened and torqued. Huge step out of the way. Finally can get the mechanic back out to approve the changes.
Old 11-25-2019, 11:13 PM
crabandy crabandy is offline
I strategically waited till the wife was at work to sneak the seatbelts into the washing machine after a brief pre-treat, they made a lot of noise but came out nice and clean! They were pretty dry out of the washer but I laid them over a chair to air dry completely. Pretty sure the only dirty spots came from maintenance.
A little inspection/Service bulletin on the wing.
I've grown tired of snagging my shirtsleeves and bag straps on the corners of my seatbacks, I trimmed them off and am currently installing a small strap of .063 to join the 2 angles together.
Lil' dude joined me as usual and went to town cleaning the belly.
Lil'dude also managed to spill the container of tail fairing screws off the bench, he found them all but 1.
RV 7 500 hours and counting
20 donation done
Old 11-26-2019, 12:57 AM
Malndi's Avatar
Malndi Malndi is offline
Default Red One in the right seat
We had the honour and pleasure of being joined by a former RAF Red Arrows lead who flew right seat with Eddie for some formation followed by a nice lunch at the HARS museum.
https://hars.org.au
A thorough gentleman and very generous with his knowledge. His insights were greatly appreciated and will no doubt assist us to enhance our own flying.
A new RV grin was firmly installed!
