  #11
Old 11-24-2019, 12:02 AM
scsmith scsmith is offline
Thanks Carl. That is enlightening, especially Ed's thread.
Originally Posted by RV8JD View Post
The additive in the Aeroshell Plus oils and its W15W-50 multi-vis oil is the Lycoming LW-16702 anti-scuff package. I just noticed this Lycoming SI also.
See this post by Ed Kollin on the differences between the two:
http://www.vansairforce.com/communit...3&postcount=10
Phillips new Victory oils also have the Lycoming LW-16702 additive package.
https://www.phillips66lubricants.com...ion-oil-100aw/
https://www.phillips66lubricants.com...-aviation-oil/
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 11-24-2019, 05:47 AM
DanH's Avatar
DanH DanH is offline
http://www.vansairforce.com/communit...2&postcount=17
Show me.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-24-2019, 08:44 AM
mfleming's Avatar
mfleming mfleming is offline
Wow, that?s scary
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
Old 11-24-2019, 11:51 AM
lr172 lr172 is offline
My understanding is that the lycoming additive package is anti-wear and does not address deposit build up. Camgaurd claims to have additives that help reduce build up. How much it helps in this area is unclear.
Larry
Old 11-24-2019, 10:20 PM
deek deek is offline
Mattituck had an informal, long-term test running outside their Long Island shop: non-airworthy cams leaning vertically against an outdoor wall covered with numerous lubricants and additives. Perhaps Mahlon will jump in and comment, but the results were similar to Dan's test.
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
