Old 11-23-2019, 07:58 AM
bkmerrill bkmerrill is offline
Question Tailcone Avionics Question
Trying to plan ahead on antenna placement in addition to other avionics that will be mounted aft of the baggage bulkhead. A few items I was planning:
  • Garmin pitch/yaw servos
  • 1 Comm antenna on top just aft of baggage bulkhead
  • GPS antennae on top of FG cabin top down centerline (planning OH console)
  • Garmin Magnetometer in Stein fuselage mount
  • ELT Antenna under tail FG fairing
  • Aerosport NACA vent valve kit
A few questions:
1) The Aerosport valve/actuator mount on upper J-channel just aft of baggage bulkhead in the area I was planning a comm antenna. Will this cause an interference issue? I plan this comm to be my ground/#2. The primary will likely be belly mounted bent whip.
2) Proximity of magnetometer to comm antenna, NACA valve servo - going to be an issue?
Brandon Merrill
Houston, TX
RV-10 ? Empennage In Progress
https://merrillfamrv10.wordpress.com/
Old 11-24-2019, 07:54 AM
Electrogunner Electrogunner is offline
Default Mag
I had my magnetometer mounted in the tail one via the stein mount. I could not get it calibrated there even after changing the rear seat belt cables to non magnetic. I eventually relocated to the wingtip and it calibrated immediately. Some people have had success with it back there. I did not.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 11-24-2019, 09:17 AM
cderk's Avatar
cderk cderk is offline
Don't know if I'm going to have issues or not, but I've located mine in the tailbone too using the Garmin mount. I have my two autopilot servos, battery, oxygen tank, transponder and ELT all mounted on a shelf right behind the bulkhead. I too have the NACA servo mounted about 2 feet in front of the magnetometer.
I've seen others mount it back there with no issues. I've got my fingers crossed because if I have to move it, it will really suck.
RV10
http://n688cd.wordpress.com
Old 11-24-2019, 11:43 AM
lr172 lr172 is offline
A few questions:
I would be concerned about having that valve too close to the magnetometer. Those servos have a winding and likely a small iron core . I made a custom valve and placed it down low, near the NACA vent and mounted the mag back near the further rear bulkhead. That gave me about 2 feet of separation and the interference test passed.
Larry
Old 11-24-2019, 08:14 PM
Thanks. I may go ahead and put the magnetometer mount there then I can leave it vacant or cut the bulk of it out if it doesn?t work. I will also plan to have a place for wingtip mount. Only concern with that is I plan to do QB wings, so not sure I?ll have adequate access to do the mount.
Thoughts on the comm antenna proximity to the NACA valve/actuator (i.e. on the skin directly above the valve)?
Brandon Merrill
Houston, TX
Old 11-25-2019, 05:27 PM
AviatorJ AviatorJ is offline
Your QB wings come essentially without the bottom skins, so you'll have some space to arrange things how you want.
Justin
RV-10, N10JW
http://operationrv10.blogspot.com/
