Old 10-23-2015, 10:49 AM
lndwarrior lndwarrior is offline
Default Alternator field wire - is the current draw continuous?
I am trying to summarize my continuous vs. intermittent electrical loads. As near as I can figure the field wire circuit draws between 2 and 4 amps.
I would like to know if the alternator field wire current is a continuous load - or a intermittent load that drops off once the engine/alternator are running?
TIA
Gary
Old 10-23-2015, 10:52 AM
RVDan RVDan is offline
Consider the field current at its max as a continuous current (because it is). Most 12V alternators have about a 4A field current at max alternator output. Some of the 70A alternators might take 5A.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 10-23-2015, 11:35 AM
bkthomps bkthomps is offline
and i've learned that if the field wire pops, you are likely hitting the "over voltage circuit" on the B&C regulators
my culprit is the cessna style master switch, which over time ~500hrs or so, they get internally corroded and cause false alarms
Old 10-23-2015, 11:37 AM
lr172 lr172 is offline
The field has a relatively linear power draw based upon current demanded from the alternator. The regulator will keep feeding more current on the field (forcing the alt to produce more current) until the voltage reaches it's set point or alternator reaches it's maximum capacity. i.e. the field current increases with the alternator output. Max draw will vary on both the alternator and regulator design. My 50A alternator would trip the 5A breaker at loads over 40 amps. Unsure if it was truly drawing 5 amps or if my breaker was tripping early. I replaced with a 7.5A breaker.
As I learned, you need to size for continuous use at full draw. If you ever run your battery down, you will run at max capacity for a period of time long enough to trip the breaker. Not something you want to learn "in the air" as I did.
Larry
Old 10-23-2015, 11:56 AM
Default Great info
Thanks for the detailed replies.
I appreciate it!
Gary
Old 10-23-2015, 01:30 PM
Kahuna's Avatar
Kahuna Kahuna is offline
You may also have a self exciting alternator. Many of the automotive alternators, particularly chevy, have this feature. Once up to an rpm, off it goes on its own and killing any field wire you may have to get it going, does nothing after it is. You can kill the field and it will keep on charging.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 10-23-2015, 03:27 PM
Kahuna,
Very few internally regulated auto alternators have a field connection. There is a field circuit, but you usually have to cut them open to get access to the field circuit. some leave an opening in the case for a technician to get a test lead on them. Some atlernators, separate the B lead, or output, from the Excitation feed (most contemporary alternators are single input). The excitation feed is typically just input power/voltage sense for the regulator and is not a field lead. It essentially creates on on/off situation for the voltage regulator. Those with separate excitation inputs will typically not produce output without voltage on this lead. In the case of single input, the excitation is bridged internally and they cannot be prevented from producing power.
Larry
Old 11-22-2019, 07:28 PM
TomDPilot TomDPilot is offline
Default Available Alternators ??
Have an RV6A with a Duralast 14184 alternator that needs to be replaced. This alternator was used in late 70s and early 80s Hondas and a replacement is not "off the shelf" taking several days to arrive. Anyone have any alternatives for an alternator that may have a more recent application?
Old 11-22-2019, 07:40 PM
moosepileit moosepileit is offline
Had same issue with the 14129.
Snagged one online, will rebuild the other for education.
Looking at switching to an IR model and adding OVP to it.
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Old 11-22-2019, 10:44 PM
I use a 14158; same era as yours. Can find them on amazon with one day delivery or local auto parts store sometimes. 50 amps externally regulated and CC rotation to match our engines.
Larry
