Go Back   VAF Forums > Regional Forums > Canada
  #11
Old 11-22-2019, 08:56 AM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Originally Posted by RandyAB View Post
Wonderful! Are you able to share the documentation that you have?
I have one friend who had major problems because his EFIS, an AFS model, wasn’t certified and therefore he needed a certified encoder for his uncertified transponder. Does your method account for uncertified components in the system?
I will need to search for it, then scan it. Will try to get it to you.
Some inspectors may take on a more aggressive stance on the certification requirement. First time I hear of that one in Canada.
At the time I did this, about 8 years ago, another builder was having trouble because he did not have analog instruments as a backup to his "dual Dynon, independent dual AHRS, each with their own backup battery". Took them a couple of years to resolve with escalation to the minister.
My inspection happened during that time, but I did have some analog steam gauges as backups ... nevertheless I created the document to placate any other concerns.
The process should be more smoother since there have been more IFR installations approved since that time.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 11-22-2019, 09:06 AM
Mousse Mousse is offline
Originally Posted by ackselle View Post
I just went through the process and had my "VFR Only" restriction removed about 1 month ago. The process was far more intimidating than complex.
Transport Canada here in Winnipeg was quite helpful, and pointed me to the Staff Instruction document # 500-024 titled "Airworthiness Evaluation of the Installation of IFR Equipment to Allow the Removal of the ?VFR Only? Operating Condition from the Special Certificate of Airworthiness ? Amateur-Built".
That document very clearly provides the guidance required to have your "VFR Only" condition removed from your CofA....specifically, section "5.0 Application" is a detailed road map(or flight plan) to the required documentation for your application.
I followed that instruction to the letter, submitted my application by e-mail (copying the local TC representative), and was notified by e-mail within a day or two that my application was successful .
Here's a link to the staff instruction letter:
https://www.tc.gc.ca/eng/civilaviati...ents-1784.html
Good luck!
Dido for my RV-10 last year. Followed the referenced document to the letter and received my new certificate the next day.
Michel
Exempted but dues paid through 12/2020
RV-9 Sold
RV-10 Flying
Old 11-22-2019, 09:25 AM
RandyAB RandyAB is offline
Good luck!
Thanks for this. It is very helpful and I will use it.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 12-07-2019, 09:55 AM
Captain Bravo Captain Bravo is offline
Thanks a lot for that link ackselle. There is an RV-8 in my future, but I don't have the time nor the space to build one. So I might consider purchasing a used one and upgrading the panel to a modern IFR one with full redundancy.
Old 01-19-2020, 05:59 AM
Jetmart Jetmart is offline
Does the requirement of 605.14 - radio navigation equipment [minimum = two pieces of equipment] mean two ground based or can one be VOR/ILS and one GNSS?
Seems crazy that you could operate today with just two ground based and not have any GPS at all with all the VOR's being decommissioned.
Has this requirement changed of late?
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
Old 01-19-2020, 10:46 AM
605.18(J) refers. The requirement has not changed. GNSS is not required but highly advisable for the coming years, as you mentioned.
My -10 was approved with one VOR\ILS and one approved GPS.
Michel
RV-9 Sold
RV-10 Flying
Old 01-20-2020, 02:29 PM
David Z David Z is offline
The way the regs are worded, you almost have to do a failure analysis on every flight. Is there any point along the intended flight and possible diversion to the alternate where you will have a single point of failure? For example, out of range of VORs and the GPS fails leaving you without navigation. Many northern airlines are finding themselves in that very position and installing two GPSs.
Going from Toronto to Montreal, you'd probably be fine with one Nav radio and one GPS (provided it's not a combined unit). GPS fails, use VORs. Nav radio fails, use the GPS.
If I were planning an IFR capable airplane, I'd seriously consider dual GTN650s. That provides dual com, dual nav, dual gps, dual screens. Need dual EFIS screens displaying that information as well in case of an EFIS failure.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
Old 01-20-2020, 06:00 PM
A second GPS is a good idea. I really wanted a GTN-750, perhaps the 750 with the GNX 375. This would give me GPS redundancy and the 375 would give me the ADSB in/out transponder.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
2020 Dues Paid
