Old 11-18-2019, 10:40 AM
lr172 lr172 is offline
Default Wing mounting question
I test fitted the wings on a stand before the gear was on. I am wondering whether I will need to support the one wing after mounting, before the second wing goes on. It is now on the gear. It seems with the engine and prop on, it may have enough mass to keep from tipping much, but just don't know.
I just need to know if I need to bring a bunch of stuff to the temporary hanger (phase I is at a different airport than my home base) to deal with this.
Thanks for the help.
Larry
Old 11-18-2019, 11:37 AM
bsvantho bsvantho is offline
With it on the gear and engine mounted you will not need any extra support. It barely budges with the weight of one wing. I was surprised. With a couple of adjustable saw horses, wing install is simple.
-Brendon
RV-10
Old 11-18-2019, 11:57 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Yep, what he said.
I had the wing on and off 4 or 5 times, use pins made from regular hardware store bolts, only use the close tolerance bolts for final install.
Congrats on getting to this milestone.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-18-2019, 02:04 PM
Yep, what he said.
Thanks for the input. It's nice to get near the finish line. Hope to have first flight before mid-December.
Larry
Old 11-18-2019, 02:07 PM
I should try that. Last time we just had the two sons hold the wing while I managed control at the spar attach and slid the bolts home.
Larry
Old 11-18-2019, 02:47 PM
Mike S's Avatar
Senior Curmudgeon
Larry
One saw horse, mid span, padding to prevent scratches on the wing lower skin.
One person on the wing tip maneuvering the wing, someone else to slide the pins in.
Mike Starkey
VAF 909
Rv-10, N210LM.
