Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
  #21
Old 11-15-2019, 09:12 PM
JimWoo50 JimWoo50 is offline
Default Drones.
That?s why ads-b. FAA probably anticipating a big increase in drone traffic. Lots of traffic without eyeballs. They need a way more precise system than radar. I?m sure drones flying above say 200 ft would need ads-b but I may be wrong.
I am usually suspicious kinda guy when it comes to govt good intentions but in this case I believe their motivations are not so much punitive.
Jim Woolard C56
N9855J RV-6 Donated 2020
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Originally Posted by Blain View Post
Never heard that. Can you cite the section that requires this?
14CFR §91.225 (f)
"(f) Each person operating an aircraft equipped with ADS-B Out must operate this equipment in the transmit mode at all times unless—
(1) Otherwise authorized by the FAA when the aircraft is performing a sensitive government mission for national defense, homeland security, intelligence or law enforcement purposes and transmitting would compromise the operations security of the mission or pose a safety risk to the aircraft, crew, or people and property in the air or on the ground; or
(2) Otherwise directed by ATC when transmitting would jeopardize the safe execution of air traffic control functions."
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 11-15-2019, 09:14 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Originally Posted by BobTurner View Post
BTW, if you have adsb-out, there is no option to turn it off. You are required by the current FARs to run it, whether in rule airspace or not.
?91.225 "Automatic Dependent Surveillance-Broadcast (ADS-B) Out equipment and use."
"(f) Each person operating an aircraft equipped with ADS-B Out must operate this equipment in the transmit mode at all times unless?
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 11-15-2019, 09:17 PM
Blain's Avatar
Blain Blain is offline
Well, I guess that answers that. I don?t think that is universally understood.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2020(my reminder)
Old 11-15-2019, 09:31 PM
emsvitil's Avatar
emsvitil emsvitil is offline
I would think there would be an emergency exception.
"I needed to shed all electrical loads except for the engine".........
Ed
Old 11-15-2019, 09:38 PM
SPX SPX is online now
Here you go...
? 91.3 Responsibility and authority of the pilot in command.
(b) In an in-flight emergency requiring immediate action, the pilot in command may deviate from any rule of this part to the extent required to meet that emergency.
RV-9A, Fallbrook Ca (L18)
Paid, Jan 2020
Old 11-15-2019, 09:41 PM
RV8JD's Avatar
Yep ... 14 CFR ? 91.3 - "Responsibility and authority of the pilot in command."
"(a) The pilot in command of an aircraft is directly responsible for, and is the final authority as to, the operation of that aircraft.
(c) Each pilot in command who deviates from a rule under paragraph (b) of this section shall, upon the request of the Administrator, send a written report of that deviation to the Administrator."
Carl N.
(Pic 1),(Pic 2)
(Pic)
Old 11-16-2019, 12:21 AM
jliltd jliltd is offline
Yes. ADS-B equipped aircraft must have the equipment powered on an operating any time the aircraft is operated. Regardless of location. Rule airspace. Non rule airspace. Ground run ups. In the middle of Montana taxiing your Skywagon on the ground from the bunk house to the barn. If you have the equipment, it must be on and operating at all times the aircraft is operated. If you ever switch it off (or loose your electrical system) you will get a nastygram from a computer in OKC. So make sure your mechanic knows he needs to have the system on when doing maintenance checks on the engine. Onerous. Orwellian. But they did it while we stood by playing the fiddle.
RV-8
(a few more airplanes too)
Old 11-16-2019, 07:37 AM
FasGlas's Avatar
FasGlas FasGlas is offline
I was told by uAvionics the same thing about ADS-B out equipped aircraft must use it on all flights but they can easily be turned off either by the app or the power. Turning it off with the app allows the IN to still work ( EX: EchoUAT ). I don't see how the feds could know if you turned it off before your flight and returned to your airport ( non rule space ). Has anyone looked into formation and ADS-B? You only use one Xponder in formation, how do you think ATC would like 8 ADS-B transmitters 20 feet apart.
Beech D17S Staggerwing
Lancair 360
Cessna 120
A&P IA
Old 11-16-2019, 08:48 AM
Snowflake's Avatar
Every time an ADS-B thread comes up, it becomes immediately apparent how few people understand (a) how ADS-B works, and (b) what the regulations are surrounding ADS-B.
Rob Prior
