Old 04-01-2017, 01:41 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Default What Avex rivets are used on the -12?
Looking to use Avex on another airplane, and want to get the good stuff. So what part numbers are used?
Thanks!
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 04-01-2017, 03:11 PM
Mich48041 Mich48041 is online now
90 percent of rivets are LP4-3.
Where extra strength is needed, the following rivets are used:
CR3213-4-02 CHERRY RIVET
CR3213-4-5
Joe Gores
RV-12 Flying
Old 04-01-2017, 03:31 PM
gossend gossend is offline
Default AVEX Rivets
Hi Ed! Long time!
Try Byler Rivets - a dealer Ph (972) 986-6792.
OBTW, I just sold that Glasair III you wrote about 25 years ago!
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with Aeromomentum AM15-HP engine
Old 04-01-2017, 05:04 PM
I was looking for a part number like 01604-00414. I don't know how to decipher those numbers for details, but I suspect that LP4-3 only specifies the size... And I'm not able to dimple, so I'm looking for plain heads.
Old 04-01-2017, 06:43 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
This might help. I don't know vendor PN's...
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
Old 04-01-2017, 06:51 PM
SR2500 SR2500 is offline
Default AVEX Rivets
Go to the Aircraft Spruce Website and search for AVEX Rivets. They will be listed as AVEX non-structural rivets. Disregard the non-structural part of the description, I'm still baffled why they do that. They have a chart that lists all the grip lengths etc. PM if you have any questions, as I'm quite familiar with them.
Best,
Jerry Folkerts
Jerry Folkerts
Pietenpol, built and sold
Cygnet SF-2A, built and sold
Cygnet SF-2A, refurbished and sold
Murphy Super Rebel, built and flying
The Pedal RV, designed and built
Vans, next build
Old 04-01-2017, 09:41 PM
John-G John-G is offline
Ed,
The rivets supplied by Van's for my RV-12 are NOT Avrex .... they are manufactured by Gesipa and are part number GSDM41-43APG. In the RV-12 plans, Van's refers to these rivets as LP4-3 rivets. The rivets are from Gesipa's series of rivets called Polygrip Multigrip blind rivets. It is an aluminum rivet with a steel mandrel that has a grip range from .039" -.197". Specifications for minimum strength are a shear of 162 lbs and tensile of 236 lbs.
The photo below shows the box of rivets Van's supplied with the RV-12 kit on the left. Also in the photo on the right are the flush rivets I purchased from Gesipa that were used to build my RV-12 (yes, I built E-AB) ... the flush rivets have the same tensile and shear strength as the low dome rivets from Van's and the part number is the same except the D is changed to a C for the countersunk version (the D is for low dome).
Hope this helps you.
Happy building,
John
www.dogaviation.com
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 04-02-2017, 06:53 AM
Ed -
Forgot to mention Gesipa has a minimum order of 10,000 and would not sell retail. I asked for and was given the name of a distributor in my area which subsequently ordered the rivets I needed for the external surfaces on the RV-12 project. (The RV-12 needed over 9,000 rivets because I went into the 10th box of 1,000).
Happy building,
John
www.dogaviation.com
Now Flying!!
Old 11-13-2019, 01:43 PM
Sclookout Sclookout is offline
Default GSMC41-43APG
Lots of great information on your build site. Can I get contact info on the Distributor you used for GSMC41-43APG rivets?
Old 11-14-2019, 08:17 AM
Sclookout -
Apparently roughly three years ago or so Gesipa changed the part numbers for their product line of PolyGrip multigrip rivets and also changed the grip ranges.
You will want to visit their website and download the new catalog ... the following link is to their catalog download.
https://en.gesipa.de/service/media_a...ads/catalogue/
As for the distributor I used ... don't remember the name because it was a one time purchase. To find a distributor, I just called Gesipa directly and asked for names of distributors in my area ... found one about 17 miles away and did a will call pickup after my rivets arrived, so saved a little on shipping. I would suggest you call Gesipa directly and find a distributor local to you.
If you still want the name of the distributor I used, PM me and I will see if I can find the receipt.
John
www.dogaviation.com
Now Flying!!
