11-12-2019, 04:18 PM
Yes, I built my own. It is in a 6, not a 10; but the principal and cost should be the same (maybe $200). I bought a Jumbo D new on e-bay for about $80, and a medical regulator for about $50. I piped it to each position where I installed stainless steal quick connect fittings that seal off the line when disconnected. The positions not is use do not use any O2. You use the regulator flow setting to adjust flow for 1,2,3 or 4 people. You could use individual flow meters, but they are ugly, bulky, clunky, and un-necessary.
Give everyone a plus-ox finger meter and adjust the overall flow accordingly.
I?ll post a parts list when I get back to the States tomorrow.
11-12-2019, 06:35 PM
Portable 4-Place Setup
Here's my budget 4-place solution. Jumbo-D Cylinder, low profile valve, 4-port regulator with CPC connector sockets. The flow meters are from eBay, mounted to an aluminum plate that attaches to the overhead via a modified GoPro mount. Works fine but it's a little bulky. The OxySaver cannulas are OK but not the most efficient technology, not an issue if you have your own fill station but no where near as efficient as an O2D2 for example.
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Atlantic crossings: 2
11-12-2019, 07:10 PM
Yes! Pictures please.
Bob
RV-10 QB Here 8-25-19
RV-7
My brain shows a remarkable capacity to not willingly accept information that it considered useless.
11-12-2019, 08:09 PM
Budget Built-In System
RV-10 N415JS
11-12-2019, 09:01 PM
Originally Posted by RV8JD
Didn?t see that one! Thanks for the link.
11-12-2019, 10:45 PM
Originally Posted by Subwaybob
That's good stuff. I'm going to use a CGA 540 so I can fill it myself.
I hope to self-fill as well at some point. You can get transfill setups for 870, as well as 540. The advantage to the 870 is the ease of filling if the need arises while away from home. Just need the Rx. Medical refill operations are everywhere and most industrial gas places will fill either 540 or 870, with an Rx.
Larry
11-13-2019, 06:19 AM
VAF Moderator / Line Boy
Larry
It's also easy to build a small 540 to 870 adapter to carry with you - I do that in the tiny jet because the built in O2 system needs filling often....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
11-13-2019, 06:52 AM
Originally Posted by Jonathan Alvord
I believe the one we used was an Inogen G3 Portable with Pulse Oxygen. It was designed as a Single user system, and we simply attached a Y connector and attached two oxysaver cannula's from Aerox. The system worked great while we were flying from Washington to Detroit this summer at 16.5k (favorable winds gave us GS 220+). We did have a pulse oximeter and were checking regularly. I believe we had it maxed out at 5lpm and our target was to simply keep OT sat above 92%. It had plenty of battery charge to get us there but we also had the 12V power adapter. I was lucky and work in the Health care industry and the local Medical Equipment supplier let me "Borrow" it for the week.
When I first bough the plane I lived in AZ and the airport FBO would easily fill my canister, however after a trip to New England and being unable to get canisters filled anywhere (rental canisters that had to be returned not just exchanged) I will probably invest in an Inogen in the future.if I have going to cross over the West a lot. otherwise I don't think I would carry the weight.
Hope that helps.
Thank you, Jonathan, that's very helpful info indeed!
I think I've found a lightly used Inogen G3 locally... that may be the path we end up going.
11-13-2019, 07:01 AM
I had the following objectives on my RV-10 Oxygen install:
- Must be a portable system. I want to be able to remove it, and refill it using a shared refill rig we setup at the Airpark (we all have $40 a refill cylinders in a daisy chain charge rig). A $40 refill lasts for a couple of years.
- Have enough capacity for two people for an east to west coast round trip assuming cruise altitudes of 10k to 16K.
- Be easily accessible to the pilot.
I selected the Mountain High pulse demand system with the AL-682 cylinder. The system comes with a nice cylinder case with tie down straps. I modified the tie down straps to have two crisscross straps anchored under four tunnel top screws. The straps have a clip so it is only a few seconds to pull the cylinder. The cylinder is mounted just aft of the front seats on top of the tunnel. The pulse demand module is mounted with Velcro on the side of the tunnel just forward of the co-pilot seat.
This setup has met all my design criteria.
Carl
11-13-2019, 07:06 AM
What are the makes/models of the regulator and flow meters?
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
