Old 11-11-2019, 10:42 PM
Robin8er Robin8er is offline
Default Rough Idle help
I recently had a Marvel 4-5 carb rebuilt for an O-360 and it runs fantastic... above idle. If I'm below about 1300 RPM the engine will surge up and down by about 50-70 rpm. Does anyone know what would cause this?
At any normal flight power setting the engine runs great, no issues. I have a wood prop, which I know is known for making idling more difficult, but I feel above 850ish rpm it should have enough momentum to idle smoothly.
Any help is appreciated.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 11-12-2019, 07:50 AM
Raymo's Avatar
Raymo Raymo is offline
1) Check primer is closed and locked.
2) Close off primer port(s) to exclude a leaking primer pump.
3) Check for induction leaks. MAP should be ~12" at idle. Higher could indicate a leak.
Ray
Old 11-12-2019, 12:33 PM
mahlon_r mahlon_r is offline
Check for a missing carb air temp port lead plug or a threaded plug there, if it was tapped at some point.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
