Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 11-11-2019, 08:40 AM
mike newall's Avatar
mike newall mike newall is offline
Default Metal Props and Electronic Ignition
Has anyone got any information regarding restrictions placed by the prop manufacturers about running metal c/s props with electronic ignition ? We are not talking high compression or tricked up motor, just electronic such as Electro-Air or P-Mags etc.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 11-11-2019, 09:11 AM
Carlos151's Avatar
Carlos151 Carlos151 is offline
I?ve got a Hartzell blended airfoil C/S prop on mine. The prop manual shows no restrictions for using electronic ignition.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
Old 11-11-2019, 09:29 AM
pa38112 pa38112 is offline
Never heard of a concern like this. I?m trying to imagine a difference that the prop would see. The fuel should burn more completely, but I do not think the rate of burn increases with E.I. so I don?t imagine there are torque spikes. -
If anything an E.I. engine will run smoother. What have you heard to make you ask?
I have an O-360-A1A running duel P-mags with a Sensench FP.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 11-11-2019, 09:30 AM
DanH's Avatar
DanH DanH is online now
And technically, "electronic ignition" has nothing to do with it.
The issue is advanced timing, not the method of generating a spark. A magneto set for advanced timing would net the same result.
It's important to remember, for two reasons. First, there are now multiple EI's available which enable fixed timing or limited advance. Second, an increasing body of evidence says the angle valve engines don't respond to highly increased advance like the parallel valve engines.
Dan Horton
RV-8 SS
Barrett IO-390
Last edited by DanH : 11-12-2019 at 05:38 AM. Reason: Removed pendulum absorber note.
Old 11-11-2019, 09:58 AM
bmarvel's Avatar
bmarvel bmarvel is offline
That in itself is ironic, given angle valve engines generally incorporate pendulum absorbers.
Dan:
Not sure what you mean by this. Is the parallel valve more or less forgiving? Please expand a bit on it. I have a P-Mag on one side and Slick mag on the other of the IO-390 in the -14A. My plan is to go to dual P-Mags when the Slick is replaced as I have had zero problems with the P (or the Slick for that matter). Would like to know more about what additional information lies between the lines of your post.
Bill Marvel, ATP, A&P/IA
Grand Junction, CO
RV-8A N751MB -1700 hours, sold
RV-14A 140134, N465MM - 670 hours and climbing
Dues paid every year
Old 11-11-2019, 11:36 AM
All good points, well presented.
Our guys seem to have an issue with EI and metal props, I think it may be historic and conservative.
I agree that the method of ignition should make no difference, there has been advice from Hartzell about EI on their props but I don't know how long ago and whether they still apply it.
What I do know is that our dual P-Mag install on our IO-360 has been perfect since 2010, but we are on an MT wood/composite prop which our chaps seem happy with.
We are trying to move forward onto SDS injection/ignition on an IO-540 powered 10. Early days but it will be a lot of work to allow it to be installed. Our lot have a big issue between 2 place and 4 place airplanes which is a historic thing again. Huge advances have been made over here over the last 5 - 10 years, we just need to keep moving forward and satisfying the regulators.
Donated in 2020
Old 11-11-2019, 02:25 PM
WAM120RV WAM120RV is offline
Default Harmonics
We had this question raised in the UK, the reason given for questioning the set up by the LAA is that they argue that the harmonincs of the crankshaft will be changed.
As a result all applications are treated as what they call prototype modifications, even though similar engines have run for a very long time with the set up. I contacted a number of owners with the same engine, prop as mine and found one with 1000 hours on the set up, with no issues.
Mine being an 0-320 E2A with 8.5/1 pistons, so theoretically a160hp, with two PMags, and at the moment a Sensenich metal FP. A lot of RV and higher performance aeroplanes over here have similar set ups.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 11-11-2019, 02:38 PM
DanH's Avatar
Not a question of more or less forgiving. As compared to an parallel valve, the angle valve merely requires less advance to reach optimum performance.
Remember, advance is compensation for finite burn rate. A better combustion chamber and port design (faster burn) requires less advance to result in peak pressure at the optimum point ATDC.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-11-2019, 02:57 PM
Full Throttle Full Throttle is offline
That's what Superior thought when they retarded the spark on the XP-400 angle valve engine from 25 to 20 degrees before top dead center.
Didn't work and they still broke cranks.
Old 11-11-2019, 03:04 PM
Vansconvert Vansconvert is offline
I have a hartzell constant speed with dual Lightspeed ignition. I bought the plane from the original builder. Documentation came with the plane from hartzell basically stating there are harmonics at play and for that reason there is a RPM / MP range that is to be avoided.
RV-7A
IO-360 Hartzell CSP
Purchased
