Old 11-08-2019, 09:38 AM
chaskuss chaskuss is offline
Originally Posted by PatriceT View Post
Hum ... Odyssey battery manual state : Monitor the batteries terminal voltage with the charger operating to assure 15.0V is not exceeded at any time....
Source : https://www.odysseybattery.com/docum..._Procedure.pdf
The battery manufacturer's recommendations would always trump the general recommendations that I gave. In my experience, only Ford calls for charging voltages as high as 15 volts. GM and Chrysler generally recommend 13.8 to 14.6 volts. Odysseys 15 volt limit is about half a volt higher than GM or Chrysler's recommendations for flooded cell batteries.
Charlie
