View Poll Results: Best place to install a shunt
On the Alt B lead 14 40.00%
On the battery 11 31.43%
On both 5 14.29%
None 5 14.29%
Voters: 35. You may not vote on this poll
Old 11-06-2019, 03:29 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default Shunt location
Curious to best location for a shunt on a Garmin single alternator system and why?
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 11-06-2019, 03:34 PM
BillL BillL is offline
On the battery. The health of the alternator to run the system and keep the battery charged is voltage. Amps will show what the system demand is if the alternator quits.
On the B lead, if the alternator quits, you can not manage the amps. In that event, volts will tell you the battery condition as it is used up.
Bill
RV-7
Lord Kelvin:
Old 11-06-2019, 06:28 PM
Bavafa Bavafa is offline
For this discussion, and assuming only one Amp meter which I have, I used the following reasoning/logic for my setup.
- On the Battery, I would expected to read mostly about a negative reading close to zero. If the alternator fails, I would expect to read a positive reading which might be for the first time or possibly during a test flight when I had shut the alternator to see what my typical amp draw is. So, to a good degree I would be unfamiliar with typical amp draw at different stage of flight. Reading on the Batt may help me during a Alt failure situation but then again, I have the volt meter which probably is just as good of indication if not better for that emergency situation.
- On the Alt, I get a reading of my typical usage at any time when the engine is running and the Alt is working. If my Amp reading changes for any appreciable amount, it may be a good indication of possible issue and investigation might be on order. For instance, Amp suddenly goes up, volts comes down might indicate a short somewhere. If my draw goes up for any long period of time, I may want to check the health of my battery or find out what has changed. If it reads zero, I know my Alt has gone south but most likely I will have other indicator to confirm that.
So, I like measure my usage and for that I installed it on the Alt side. With that, I know how much my LL draw, what my heated seat use or the fuel pump.
But it is only $$$ so why not install two.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-06-2019, 07:19 PM
Mich48041 Mich48041 is offline
The voting choice "On the Battery" means to measure all current into or out of the battery EXCEPT starter current.
I vote for none because if it is not installed, it can not fail or make sparks during a forced landing.
A voltmeter reading of 13.5 or more indicates that the alternator is working. If you really want to know the current,
put a hall effect sensor around the alternator B lead to measure how hard the alternator is working.
The RV-12 ammeter was designed to measure battery current. Their reasoning is that in case of
alternator failure, the pilot could shut off loads based on current flowing out of the battery.
Why not just shut off everything that is not needed and fly the plane?
Joe Gores
RV-12 Flying
Old 11-06-2019, 07:26 PM
emsvitil's Avatar
emsvitil emsvitil is offline
What do you want to measure?
1. Amp output of alternator?
2. Amp load of lights, instruments, etc?
3. Amps to/from battery?
If you do 1 & 2, you can derive 3 in your head.
Ed
Old 11-07-2019, 03:45 PM
AviatorJ AviatorJ is offline
I have two alternators, I did two alternator shunts off the B leads... This is mainly because I have a VPX and that gives me a good bit of info as well.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 11-07-2019, 04:38 PM
Steve Iacoviello Steve Iacoviello is offline
I put mine on the B lead. In most of my flying it tells me load on the system. I can also see the condition of my battery right after start when additional amps are drawn for charging. If more amps or more time than typical is needed to charge the battery I conclude that the battery is getting weak. In the unlikely event I lose the alternator volts will provide what I need to know.
RV-9A completed 12/2011
N579S
Old 11-07-2019, 07:40 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
And if you add #2 and #3 you get #1. At least for me, adding is easier than subtracting.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 11-07-2019, 08:35 PM
rswalden's Avatar
rswalden rswalden is offline
On the BATTERY.
That always tells me the battery state, with or without the alternator working.
In normal flight with alternator online, I will see +14 volts with 0 amps drawing from the battery. Good. I know the battery is fully charged and the alternator is carrying the full load. How many amps is the alternator producing? Simple. Turn off the alternator and read the current draw from the battery that was provided by the alternator. Want to see if your landing light is working? Turn on the switch and you'll see a momentary load on the battery before amps returns to zero.
Now...If the alternator fails in flight, I again see the discharge RATE of the battery. That helps me reduce the load if necessary by turning off high-draw items... extending the time I can stay flying. If the shunt had been wired to the alternator, amps would show zero. No useful info. I have a red alternator off light that tells me that. No value added.
Also, before starting the engine, I always see the discharge rate of the battery which is useful for reducing the loads while waiting.
One final good reason: I use the experimental EarthX battery which handles huge surges of current during start. It draws a lot of current from the alternator to bring the charge back to zero. I like to keep close watch on the EarthX voltage and amps... In fact, that battery requires a blinking status light to troubleshoot malfunctions. Putting the shunt on the battery gives me a way to constantly monitor volts AND amps.
My opinion: There is no advantage to putting the shunt on the alternator, while wiring it to the battery gives me constant power monitoring from before engine start until after engine shutdown.
Of course, this a lot like our "Primer Wars" debates...lots of opinions!
Bob Walden (Waldo), CFII-ASMEL, Commercial Glider
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 700+ Hours
EAA/AOPA/Vans Air Force 2020 Supporter
Old 11-07-2019, 11:04 PM
MCA's Avatar
MCA MCA is offline
I agree with Joe on this one.
Volts will tell you everything you need to know. One could argue that you don't need to "manage" the load if the alternator fails. Just turn off things you don't need and watch the voltage drop over time.
You should already know the high current items from the low current items as part of your electrical system planning. So knowing what to shut off is not too tricky.
While a shunt is not too complicated, it is one more thing to break.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
