11-05-2019, 07:04 AM
Running wing conduit
Studying Vans PDF and other builders pictures - the wiring conduit is run on the bottom of the ribs, closest to the ground when wings level. Vans says to use some sealant to keep the conduit from chafing. Watching the GBO video, it's suggested to run the conduit after riveting each individual rib/bottom skin so as not to interfere with the bucking bar for that rib. It would seem very difficult to add sealant 'as you go', vs before riveting the bottom skin on. Thoughts? Does anyone run the conduit closer to the top skin? Just install the conduit and work around it to buck? Not use the RTV at all?
John
RV-7 Slowwww build
11-05-2019, 07:24 AM
conduit
Here's how I did it, and it really worked well. Easy to get all the cables in that I needed. I had to create a cutout to exit for the wing servo, and that also just required a couple of holes.
http://www.rv8.ch/wing-wiring-conduit/
11-05-2019, 08:16 AM
cpvc
Mine is similar but I used joist hangers:
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
11-05-2019, 08:25 AM
Conduit
I installed the black stuff Vans sells in the designated location before riveting bottom skins. No problem bucking rivets. Adding a dollop of proseal at each intersection was easy. Just reach in with a glob on a popsicle stick. All it does is prevent the conduit from vibrating.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
11-05-2019, 08:26 AM
It?s not a big deal to rivet around the conduit if located where Vans suggests. I would highly recommend installing while the skins are off.
John
RV-7 Slowwww build
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
11-05-2019, 08:49 AM
Just me
I ran the corregated Vans conduit in the designated holes. I ran the conduit before the bottom skin was on with no trouble riveting the bottom-skin. I also stretch the conduit so it wouldnt rub on the bottom skin in light turbulence. It was easy of added the proseal with the skin off.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 5% in work
Firewall Forward 5% in work
11-05-2019, 10:25 AM
Larry/John,
Did you find it a tight fit running the conduit? Seems like it will take a while to get these installed using the called out hole diameter.
Joe Granito
Albany, NY
RV-7A
Emp completed
Wings at QB stage
Canoe flipped
Finish kit Arrived
2020 donation sent
11-05-2019, 02:37 PM
Vans plan
I used the details on Vans optional plan and drilled the holes accordingly. The corrugated conduit fit in tight and i had to pull it thru with it snapping thru each corrugation.. but it worked as advertised.
John S
RV9A- Status:
Tail 98% done
Wings 98% done
11-21-2019, 12:14 PM
wing conduit in a mounted wing of a flying aircraft
Running wing conduit in a mounted wing of a flying aircraft?
The second avionics update for my store bought -6 had me install an OAT probe close to the aileron bellcrank access on the right wing.
There are several ways to do this, the one used here was "cheap" and required awkward gymnastics... why are my arm and fist joints where they are and not where required for the task I ask
In a nutshell:
- had some leftover conduit as used when I built the -4 (just about 30 years ago...), only 4mm i.d. but plenty for the wire used
- the search engine is your friend and Mouser has exactly what I was looking for: Harness Clip, Mouser P/N 523-ALBCBS3045909. Right size and enough clamping pressure
- gain access to the ribs, e.g. remove the right seat and panels below, remove the aileron boots, remove the 2 bolts holding the right aileron pushrod and push it to the other side, and open the right aileron bellcrank access panel
- clip the clips on the ribs: for the hard to reach middle ribs, precisely measure the between ribs distance, then drill/dremel the cavities for the clips on a 2x1". Attach the conduit held to the clips by plastic ties onto that piece of wood, secure with some thin masking tape. Insert that contraption from the access panel side, adjust and slightly hammer the 2x1" down and remove it. For the rest of the clips, try retracting all muscles and bending the bones of your arm to reach the clips on the ribs from inside the fuse and the access panel...
- reinstall everything and check the clearance between the aileron pushrod and the clips
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
11-21-2019, 01:14 PM
Conduut
Originally Posted by Kitbuilt
Larry/John,
Yes. Just keep pulling. It will go.
Larry Larson
Estes Park, CO
Disclaimer
