11-03-2019, 02:40 PM
Originally Posted by Jonathan Alvord
I've been chasing some pmag issues over the last few weeks. 1st noticed as my RPM was jumping around and then just stopped working. We cleaned all the contacts and then it appeared to be working well again, but soon started bouncing again. There was no change when doing run ups an checking mags. Last week I replaced the plugs (clearly the gaps were off) when I took the plugs to NAPA I was given a replacement plug and told it would be good, needless to say the plug was 1/2inch shorter thread, and 1" longer top (Obviously not a replacement). The original plug was NGK R 3035 BR8ECM, which is interesting now as I read the above and there is no mention of that number. I'm still trying to figure out which PMAG it really is, and how to service it. The RPM's are reading normal but jumping occasionally to a higher RPM. Any insight would be great.
Jon
I wonder what the difference between a BR8ES and a BR8CEM is? I've been running the BR8ES with good results, but I think I might try the Autolite 386 next time I do a condition inspection (January). I am also going to see about sending my E-Mag 113 in to have it converted to a P-Mag 114. I read on another post it is about $380, money well spent as far as I'm concerned.
RV6 N7219d
IO-320-B1A
Sam James cowl
first flight May 2, 1997
RV8 #83830 tail done, wing done
Fuselage started
11-03-2019, 06:03 PM
Most important is that you get the latest firmware update to your P-mags. This is critical for continued safe operation.
I have been running 114 boards in my 113 P-mags since the 114's came out. No issues at all. Well worth the cost of the upgrade!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-03-2019, 06:54 PM
Originally Posted by Skysailor
There are four RV's I know running Autolite 386 plugs with the PMAG including mine. All report excellent results.
Thanks, good to know. I think I will switch back to the Autolite 386 at next condition inspection.
Dan Thompson
RV-6A - N426JM - 180hp / C.S. / dual PMags
NC26 - Long Island Airpark, NC
11-04-2019, 05:26 AM
Originally Posted by N941WR
We do not recommend running past 100 hours with any automotive spark plug.
The reason is that with an EICommander installed, the pilot will notice the deterioration of the spark event once past 100 hours. This is regardless of if the standard plugs or iridium plugs are installed.
The pilot will not notice a difference unless they have a way to "read" the P-mag spark events.
Did you ever find that report?
http://www.vansairforce.com/communit...3&postcount=14
Dan Horton
RV-8 SS
Barrett IO-390
11-04-2019, 12:39 PM
Where do you get this from, and how do you update it?
N122EF RV7A
S40 Prosser Washington
=VAF Dues paid 2019=
11-04-2019, 12:57 PM
I'm not sure what form you mean. I contacted E-Mag today, they told me that it will cost $350 to upgrade from an E-Mag to a P-Mag with the firmware updates. They told me the turn around time is 3 to 4 days.
RV6 N7219d
IO-320-B1A
Sam James cowl
Fuselage started
11-23-2019, 04:58 PM
I too use 386 plugs
Started with BR9-ES but wanted to ditch the adapters so switched to 386 plugs on my pmag 200 hrs or more ago. When I added second p mag I went right to 386 plugs. They are $8 for 4 of them so when I change oil at 25 hrs I replace top or bottom plugs alternately. Usually discarded plugs are in pretty good shape with minimal lead deposits.
Jim Woolard C56
N9855J RV-6 Donated 2020
