11-03-2019, 09:40 AM
Mentor
Daniel
There are lots of experienced builders around Austin. I'm originally from Austin. 30 years. Locate one willing to be your Mentor. Spnd some quality time learning how to do it right. Don't waste time trying to teach yourself.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
11-03-2019, 10:56 AM
If your drilling the holes There's a possibility that the end result is a bit larger than a true #40 hole. You can always start with a next size down drill bit and then a #40 reamer to get a nicer hole. But either way the dimpling process does enlarge the hole you started with. I have found on the RV-14 pre-punched holes if I deburr them as is and then dimple without enlarging to #40 the dimpled hole is a bit smaller and the rivet/cleco's fit better.
On a related issue I have found that dimpled holes because they are bigger than the rivet, will result in a bit of wobble with the rivet. this makes for a higher probability of driving the rivet at an angle and having to remove it. Pre-squeezing the rivet with a pneumatic squeezer to make it fatter by a bit results in less rivets having to be drilled out.
If you have had to remove rivets the hole tends to be a bit bigger from the riveting process and removal so a pre-squeezed rivet (sometimes the next longer size) will also help from multiple removals of the same rivet.
If I had it to do again I would have completely disassembled and re build the tool box kit and aileron training kit at least once each. Makes for great practice all the way around. You will need to know how to remove rivets and deal with stubborn larger holes.
Yes Oops rivets work but I save those for my 3rd or 4th attempt at fixing a stubborn rivet.
Good luck
11-03-2019, 01:54 PM
I don't have a full drill set, but I do have a 7/64" bit. It is very tight in the 3/32" dimples and passes easily into the substructure dimples.
I used a micrometer to measure the holes:
drilled hole measured .094"
3/32" dimple hole measures ~.105"
substructure dimple measures ~.108"
so if the #40 drill bit is correct at .098 I'm measuring about .004 small. 7/64" is .1094, which puts the substructure dimples at about .112, which checks.
I tried a bunch of cleco as well and some would hold and other wouldn't. I bought the cleco brand new from ATS so I would think they'd be ok, but there's definitely variation in holding power among them.
The AD3 rivets seem pretty sloppy in the dimpled holes to my eye, but I have no idea how much slop there should be.
Probably should just join a local chapter now that I'm practicing. I signed up for the EAA sheet metal class in Houston Dec 14-15 and maybe they'll be able to straighten me out.
11-03-2019, 02:10 PM
Clekos
Specs sound correct. Personally, I only used substructure dies if there was a third layer. Tank dies were used on the second layer. Thousands of RVs have been built with just #40 skin dies.
I still think the issue is Clekolok clekos. Borrow a Wedgelock and I bet you'll see the difference. In the meantime, grab a handful of 4-40 nuts and use them on the inside to keep the cleko from popping out. I bought a box and drilled them all #40. They come in handy. Used them on the tanks. Thankfully my bucket of Clekolock clekos is no longer used. I plan to sell them cheap when my bird is done.
Larry Larson
Estes Park, CO
Disclaimer
11-03-2019, 02:43 PM
Well, I guess that's what I get for buying sale item cleco's
Luckily I only bought 60 for the training kit. I'll order the better ones from Cleaveland next week and see if that helps.
11-04-2019, 01:31 PM
Not sure where you're at but I'm in Pflugerville and have some Wedgelocks if you'd like to give them a shot.
My initial batch of Clekos came with my tool kit purchase from Isham, second set came direct from Van's and they seem by far the worst (also branded Clekolock). The 3rd batch were WedgeLocks and the difference is pretty notable (as it should be as they're significantly more!). The ones from Isham seemed in the middle of the two. But the ones from Van's almost seemed defective with a lot of the "points" being misshaped.
If you want to try the WedgeLocks out before you make a decent investment in Clekos let me know.
Jared
11-04-2019, 03:57 PM
Just me
I would not use substructure dies... too many people had too many problems. Substructure dies seem to be a bit of overthinking. I bought my clecos from Browns Tool and they are Boeing quality; never had an issue.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 5% in work
Firewall Forward 5% in work
11-04-2019, 04:51 PM
I live south but I work in Cedar Park - maybe we can meet for lunch sometime and I can show you the progress I've made on the practice kit (or lack thereof).
11-04-2019, 06:34 PM
Help
Daniel
I will be in Austin for two weeks around Thanksgiving. Happy to help if you still need. I will be staying in Buda. Feel free to send a e-mail. Address is in my signature below.
Larry Larson
Estes Park, CO
Disclaimer
11-05-2019, 11:02 PM
Shoot me a PM and maybe we can meet up. I work central. I?ll dig through the clecos and find a couple of wedgelocks to hand off for you to try if you want to meet up.
Jared
