Originally Posted by chaskuss
Rich, GRT does not offer Kavlico transducers as an option at this point in time. However I got off the phone with Eric at GRT earlier this morning. I explained to him the basic parameters of the Kavlico P4056 series transducers. He assured me that they can be made to function using the six auxiliary inputs that the EIS 4000 + 6000 give you. It's a simple matter of inputting the correct offset in the software so that the transducers will be accurate. I've sent him my serial number and software version and the datasheet for the Kavlico transducers that I would be interested in using. Once he reviews the information he will contact me and give me the offset that I need. Anyone else wanting to use the sensors would have to pick the exact sensor they want to use and then contact GRT support. You'll need to supply the exact Kavlico sensor info, your serial number and the software version that your unit has. It all makes a difference.
Charlie
You positive about this? When I set up my EIS system, I was able to create custom offsets/configs for every sender except the Oil pressure. The EIS did not allow custom config for the oil pressure input. Have no idea why. Possibly they changed it.
I did a kavlico for the fuel pressure. Takes a bit of math, but very doable. I also did a custom setup for the MAP to use a cheaper, GM sensor.
Larry
