Old 10-26-2019, 01:53 PM
terrykohler terrykohler is offline
Default Overvoltage Warning
Started the plane today and got an overvoltage warning on my GRT Mini. Voltage was reading 14.4 on the gage, which is a bit higher than normal. Is this an indication of a failing voltage regulator (I have a Nippondenso alternator with built in regulator)? I can probably increase the warning parameters on the GRT, but am I risking damage to any of my avionics or electrical? What?s a ?safe? upper limit?
Terry, CFI
RV9A N323TP
Old 10-26-2019, 02:43 PM
chaskuss chaskuss is offline
Default The sky is falling, the sky is falling!
Terry, CFI
RV9A N323TP
14.4 volts is within the normal charging range for GM Chrysler and Nippon Denso alternators. You need to raise the alarm level on your mini. Ford voltage Regulators normal is 13.8 to 15 volts. If you're using an Odyssey battery or some other form of sealed battery you actually would like the charging voltage to be about half a volt higher than what is normally used for flooded acid batteries. I would suggest you raise the alarm level to about 15.5 volts. I know the alarm level on B&C's voltage Regulators is actually 16.0 volts.
Charlie
Old 10-26-2019, 03:31 PM
Default Thanks Charlie!
I?ll reset tomorrow. I?m doing my condition inspection and probably let the battery run down too much while testing things. Never saw the warning before on my EFIS, but it was the end of a long day and brain and body were running on reserve. Appreciate the details in your response.
Terry
Old 10-26-2019, 07:40 PM
N804RV's Avatar
N804RV N804RV is offline
B&C's over voltage warning kit has their gizmo preset for 15.2Vdc. The failure I saw was an occasional flicker of the over-volts warning lamp, gradually progressing nearly full time. Buss voltage was 15.4 volts at that point. Replaced the external rectifier/regulator on my 2-wire system and all is good since.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 10-26-2019, 09:16 PM
PatriceT PatriceT is offline
Charlie
Hum ... Odyssey battery manual state : Monitor the batteries terminal voltage with the charger operating to assure 15.0V is not exceeded at any time....
Source : https://www.odysseybattery.com/docum..._Procedure.pdf
Patrice Theriault
contact@patricetheriault.com
RV-10 Enthusiast
Zenith CH-250 C-FRSH - flying
Lachute Airport (CSE4) Lachute, QC, Canada
Old 11-07-2019, 11:16 PM
MCA's Avatar
MCA MCA is offline
16 volts is the normal upper limit. Most modern avionics can support up to 32 volts, and temporary excursions above that for very short periods of time (<1 sec).
Overvoltage conditions need to be rectified within milliseconds, so it's best, IMO, to have some sort of OV protection system that can shut down the alternator much faster than a human. Your OV alarm is usually a popped alternator field breaker.
Low voltage is a different beast, and is not nearly as time-critical.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 11-08-2019, 12:15 AM
emsvitil's Avatar
emsvitil emsvitil is offline
I know automotive voltage regulators regulate the voltage based on outside temperature.
The colder it is, the higher the charge voltage can be for a lead-acid battery.
So the regulators will raise the voltage when it's cold.
Airplane regulators probably do the same thing.
Ed
Old 11-08-2019, 06:15 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Not sure what era you're talking about here but I don't see this on any of my Denso, Hitachi or Bosch equipped alternators circa 1990-2010.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 11-08-2019, 09:13 AM
Default Please clarify
I'm a little confused here. What do you mean by B&C over-voltage kit? My previous comments were based on B&Cs LR3C voltage regulator technical manual revision C Circa 2016 09 16.
https://bandc.com/wp-content/uploads...anual_revC.pdf
On page six it states: " the integrated over-voltage protection function is set at a non-adjustable 16.0 volts plus or minus 0.2 volts on the LR 3 C - 14." On the top of this same page it also states that this voltage voltage regulator comes preset to a charging limit of 14.4 volts. However the user can adjust the maximum charging voltage as he or she sees fit.
Perhaps we are referring to two different B&C products??? Since you mentioned rectifier regulator I suspect that you are dealing with either a model SD - 8 or model SD - 20 Dynamo style backup alternator system.
Charlie
Last edited by chaskuss : 11-08-2019 at 09:46 AM. Reason: Added web link to quoted document
Old 11-08-2019, 09:26 AM
Default Not quite
Ed, that's not quite right. Automotive internally regulated alternators can only measure their own temperature. They can lower or raise the charging voltage based on that temperature. The assumption is that the battery is also located under the hood and therefore will be at a similar temperature.
Some modern automotive and marine charging systems have the voltage regulator built into the PCM ( powertrain control module AKA engine computer). These systems can monitor the temperature of the alternator and also of the battery. They are able to adjust the charging voltage to compensate for either of these items starting to overheat. As you also mentioned they can raise the charging voltage when the temperatures are low. This is being discussed on another thread here. I believe the title of the thread is PlanePower versus B & C.
http://www.vansairforce.com/communit...d.php?t=176462
Charlie
Last edited by chaskuss : 11-08-2019 at 09:53 AM. Reason: Added weblink to thread referenced
