Old 10-18-2019, 06:34 PM
ronmachisen ronmachisen is offline
Default Pitot in Right Wing
Builders,
I'm ready to install the Garmin GMU22 in the left wing. I have the Garmin Pitot with controller and have been reading about the interference with the GMU. What is wrong with putting the pitot in the right wing to eliminate any interference? Would there be a problem putting it in the right wing. I do have the Garmin smart servo going in.
Old 10-18-2019, 06:38 PM
Mel's Avatar
Mel Mel is offline
No problem at all.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-19-2019, 12:10 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Thats what I did with no problems.
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 10-19-2019, 06:19 AM
Reflex Reflex is offline
No problem at all. Almost did that myself. Decided that with the roll servo in the right wing that I'd be sending power to the servo far more often than I would to the heated pitot so I stuck with the left wing.
Was a tough decision, the heated pitot will likely emit far more EMI, but should be used less often. However, when used, you are likely in IMC. The roll servo will vary in voltage (creates EMI) as it actuates, but uses far less current and EMI should be significantly less.
Ended up putting heated pitot and magnetometer in left wing with twisted #12 as per Garmin and Vans. Wire is roughly 14" away and perpendicular to magnetometer wire at closest point.
It should be noted that my plane isn't flying yet so I can't report on how my system actually works.
Dues Paid for 2020
RV-14
Empennage Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse joined and working on painting interior
Old 10-19-2019, 06:47 AM
Tom023 Tom023 is offline
As another option, I put the GMU22 in the right wing tip and have zero issues. Stein makes sturdy aluminum bracket for just this purpose...be sure to specify left or right tip.
RV14A #140083
Flying! 8/12/19
2019 Donation
Old 10-19-2019, 08:33 AM
I'm not familiar with the -14. Is there a hole already in the left wing skin for a pitot tube that you'll have to fill?
Dave
Old 10-19-2019, 08:38 AM
Default Pitot hole
There is no accommodation for a pitot hole so it doesn?t matter which wing since you have to make the hole.
Old 10-21-2019, 07:46 AM
asw20c asw20c is offline
I kept my Garmin heated pitot in the left wing, used twisted pair in flex conduit as far away from the GMU as I could route it, and then wrapped mu-metal around the conduit to help shield the GMU from any EMI. I opted to not use the controller model because mounting it just added more complications. My understanding is that any interference, and I doubt there will be, only occurs when turning it on and off as the field builds and collapses. Another reason to not use the controller model. Just be aware that anything you do in the wing root area, like adding conduit, just makes riveting the bottom skins on an order of magnitude harder because you now have a new obstacle to contort your bucking hand around. For me this wasn't trivial so make informed decisions before you do anything off-script.
Having said all that, and for full disclosure, I'm not flying and haven't actually tested this arrangement yet.
Empennage Complete
Wings Complete
Fuselage Underway
Old 10-21-2019, 11:35 AM
Originally Posted by asw20c View Post
. My understanding is that any interference, and I doubt there will be, only occurs when turning it on and off as the field builds and collapses. Another reason to not use the controller model. .
For most avionics, this is true. But the magnetometer is designed to look at the steady-state earth?s magnetic field, so any stray fields-even dc ones-can affect it.
The first time you forget to turn pitot heat off, and then burn your skin when you touch it, you?ll wish you had had the controller! Been there, done that.
