View Poll Results: Have you replaced one or more of your RV8 engine control cables?
Yes, at under 500 hours.
10 |
29.41% |
Yes, at under 800 hours.
8 |
23.53% |
Yes, at under 1100 hours.
1 |
2.94% |
I have never replaced my RV8 engine control cables
15 |
44.12% |
04-05-2019, 04:15 PM
Originally Posted by Ironflight
Ed - just a recommendation based on my own experience - they get really bad quick - if it?s taking two hands to get it ?off?, then ground the airplane now until the cable is fixed - you might only have one operation left.
Paul
Agree. I grounded it Sunday while I come up with a plan. Tried lubricating, no joy. Just need to decide which cable to order exactly.
Question asked by custom cable supplier:
Will the clamp sleeves need to be threaded????
Ed Neffinger
KCCR
RV7a
RV7
RV8
ATP, CFIA, II, ME, G
04-05-2019, 04:29 PM
Just buy the drop-in replacement from Van's. It is an $80 fix that will last years. I replaced my engine cables after about 15 years on the RV-6 and expect the current set to last that long too.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
04-05-2019, 08:51 PM
VAF Moderator / Line Boy
Originally Posted by Kyle Boatright
Just buy the drop-in replacement from Van's. It is a $80 fix that will last years. I replaced my engine cables after about 15 years on the RV-6 and expect the current set to last that long too.
That?s what I did on the -8, and after adding heat protection, the cables have gone 1500 hours....
I used different cables on the -3, but modifying the -8 would have been painful after its was finished and flying.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
04-06-2019, 09:26 AM
If you want to know if the heat is affecting them go fly the plane. I think that's what's happening to my throttle cable. On the ground it's stiff, but moves. Once I'm flying it moves super freely so I'm thinking the heat is softening whatever inside is binding the cable.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
04-06-2019, 11:10 AM
Careful - when it happened to me, heat made it worse, and while it operated on teh ground, it froze up on me in flight, and we couldn?t do an idle/cutoff shutdown at the end of the flight.
Paul F. Dye
04-06-2019, 06:51 PM
Careful -... heat made it worse, and while it operated on the ground, it froze up on me in flight, and we couldn?t do an idle/cutoff shutdown at the end of the flight.
My main symptom was the binding of the mixture cable when trying to pull it to idle cutoff. Had to use two hands to get it shut down.
Today I removed both the throttle and mixture cables... PIA! The prop cable is still working like a champ. The governor's on the back, so it's not close to the exhaust. I disconnected the throttle cable and worked it by hand and it was binding significantly, although less than the mixture. So it will be replaced as well.
I measured them and am ordering new Van's cables.
Ed Neffinger
KCCR
RV7a
RV7
RV8
04-07-2019, 01:36 AM
I think the answer to this is YES. The ends of the outer sleeves are threaded to hold them to brackets at the ends.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
04-08-2019, 09:17 AM
I had to replace my original green Van's cables at about 500 hours. I installed heat shields and fire sleeve on my throttle and mixture cables. At 1000 hours they became stiff again and I replaced them with custom McFarlane cables. They are still going strong at 1600 hours. They are three time the price of the Van's cables, but if they last me twice as long I'll be happy since replacing cables is such a pain.
Jerry Esquenazi
RV-8 N84JE
10-16-2019, 09:39 AM
another version
Here's the drawing for the custom throttle cable McFarlane made for me. I've been using it for quite a while now, no issues. The quadrant end length was a little different than the original Cablecraft/Vans cable, I had to find a shorter clevis fork to work in my installation, otherwise very happy with it.
Greg Blanck
RV-8 Completed March 2014
Redwood City, CA
RV-8 Build Log
10-16-2019, 01:49 PM
Greg,
thanks for posting the order form for McFarlane. I am getting ready to order both a mixture cable and a throttle cable. Can you confirm the equivalent length of the standard Van's cable that this replaces? Is it a QT-60? I'm guessing because the sum of all the individual lengths is 60". I can't recall if the Van's cable lengths are listed as full overall length? Could you have specified different lengths so that the standard quadrant clevis fork would work? Did the threaded sleeve ends come with the same thread diameter as a standard Van's cable?
I put firesleeve on my original cables. The throttle cable failed after about 450 hrs. I installed a new Van's cable and did firesleeve + aluminum tape wrap + an additional heat shield. Now the mixture cable is failing at about 600 hrs.
Kyle, with an RV-6 or -7, the replacement procedure is easy enough that it makes sense to just keep buying the $80 Van's cables. On the RV-8, the replacement procedure is so difficult that I only want to do it once more. I am willing to spend the $300 or so for a McFarlane cable that will for sure last the life of the airplane instead of having to do a painful replacement every 500 hrs or so.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
