  #11
Old 09-23-2019, 01:01 PM
Onewinglo's Avatar
Onewinglo Onewinglo is offline
Originally Posted by elev666 View Post
JP , would you happen to remember were you sourced the butterfly valve you used , I’m using a FW mounted 13 row and there will be days I need to close off cooling air flow here , yours looks nice and light and will save me reinventing one here !
Aircraft Spruce 3". The flange on the baffle came from Spruce also.
https://www.aircraftspruce.com/catal...?clickkey=7368
A better view.
https://photos.app.goo.gl/d9FPhN24KVj4NZgz6
JP White
RV-8 "EL CABALLITO"
Cessna 170A SOLD
2021 Dues Gladly Paid
A new pilot having fun!
Old 09-23-2019, 02:37 PM
scsmith scsmith is offline
JP , would you happen to remember were you sourced the butterfly valve you used , I?m using a FW mounted 13 row and there will be days I need to close off cooling air flow here , yours looks nice and light and will save me reinventing one here !
I made my own 3.5" butterfly valve that mounted to the rear baffle and then attached a 3.5" scat tube to run to the cooler. I am now in the process of increasing to 4" scat and a 4" butterfly valve -- I think the 3.5" is a little too small for the large oil cooler for the angle valve engine.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2021
Old 09-23-2019, 03:34 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by Danny King View Post
I am currently using the 10599 on my I0360A1B6 and cruise around 200F-205F. I know that is within limits, but would love to cruise closer to 190F. Would swapping my 10599 for a 10611 accomplish that?
Probably, depending on upper and lower cowl pressure. I can tell you how to measure it if you wish to have assurance before doing the swap.
I have some cowl pressures for RV-8's. I'll look at the numbers. Remind me if I forget.
Will the 10611 mount in the foot print of the 10599? My 10599 is mounted behind #4 on the aft baffle.
No, it is physically larger, and will probably need to be remote mounted.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-10-2019, 10:28 AM
FlyGood FlyGood is offline
For Dan: For your converging oil cooler exit duct, what is the ratio of the duct exit area at the bottom of the cowl to the area at the exit of the cooler?
Ken Cockrell
RV-8 Fuselage Slow-Build In-work; on gear
Tail Kit complete
Wings In-work
N247TM Reserved
Old 10-10-2019, 11:22 AM
DanH's Avatar
It does not extend all the way to the freestream, but rather to the top of a converging exit bell exhausting all the cowl air. Oil cooler mass flow meets the majority mass flow at a right angle, more or less, so I didn't want significant velocity. So, if the duct exit is smaller than the cooler face area, it is not by much. The area was set by the available space between engine mount tubes. I do not know the exact area.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-15-2019, 10:22 AM
Thanks, Dan. This will be another fun aspect of the build!
Ken Cockrell
Tail Kit complete
Wings In-work
N247TM Reserved
Old 10-15-2019, 11:17 AM
RV Jerry RV Jerry is offline
Another consideration for oil cooler size is type ,drawn cup vs bar and plate, the bar and plate will typically be more efficient for heat dissipation due to fin design and area. I think before deciding on size alone the type of cooler should be considered.
Jerry Scott
Rocket II
Old 10-27-2019, 09:31 PM
Rallylancer122 Rallylancer122 is offline
I just redid the oil cooler install in my Dad's RV8. IO390, Sam James cowl, and it had an 11 row Niagra on the left side that just wasn't cutting it. I was regularly seeing temps in the 210-220 range, and that was babying the engine.
So I bought an airflow-systems 13 row cooler and installed it on the right side. Basically I copied the showplanes installation. I would have just bought theirs but I have non-standard baffling so I built my own. In hindsight I probably should have just bought the showplanes kit and modified it. I looked at some more exotic coolers, but the 2006x appears to be a form/fit replacement for a 13 row Harrison which is pretty common. So if I'm ever somewhere and it fails odds are I can get a replacement quickly to get me home.
So far I'm quite happy with the results. Temps are consistently in the 180's, however our ambients in Wisconsin are cool right now so we'll see how it handles summer.
DEM
Old 10-28-2019, 04:35 AM
chaskuss chaskuss is offline
Default Examples of each Style please
Jerry could you please provide links to examples of each of the two styles of oil cooler you have spoken about? Would I surmise correctly to think that the old Harrison is an example of one style and that is Stewart Warner would be an example of the other?
Charlie
Old 10-28-2019, 11:42 AM
You ca tell by looking at cooler the bar and plate has what looks like a tank at ends of cooler a drawn cup looks like the individual row of fins extend all the way to end of cooler.
Hope this helps
Jerry Scott
Rocket II
