Old 10-08-2019, 04:59 PM
togaflyer togaflyer is offline
Default I?ve switch to the Bunny
So after many years of using Duracell batteries, I’m done with Duracell and have switched to Eveready batteries. Over this last year, those Duracell’s have failed and leaked in three of my flashlights, leaving a corrosion mess. It was hard to pass up those big packs of double A’s at Costco, but so far I have had good results with the Eveready’s. Just a PIREP, check those batteries occasionally that are in your devices.
Old 10-08-2019, 05:18 PM
RV8JD's Avatar
RV8JD RV8JD is offline
I have found the same thing with Duracells over the last few years. They used to never leak. I guess I'll switch to the Bunny also!
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 10-08-2019, 05:20 PM
Mel's Avatar
Mel Mel is offline
Default Me Too!
Originally Posted by togaflyer View Post
So after many years of using Duracell batteries, I?m done with Duracell and have switched to Eveready batteries. Over this last year, those Duracell?s have failed and leaked in three of my flashlights, leaving a corrosion mess. It was hard to pass up those big packs of double A?s at Costco, but so far I have had good results with the Eveready?s. Just a PIREP, check those batteries occasionally that are in your devices.
I've had similar experience with Duracell. They were my "go-to" battery but recently I've had several fail & leak also.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-08-2019, 05:26 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Same here - even leaked in the package!
They have destroyed several devices I have owned!
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 10-08-2019, 05:29 PM
RVDan RVDan is offline
Yep, Duracell?s, or Costco brand are reliable leakers over time. Only put them in things you don?t want to keep. Energizers for me, no leak.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 10-08-2019, 07:18 PM
RV10Man RV10Man is offline
I've started taking the batteries out of everything until I'm ready to use it. I even take them out of the headsets.
RV9A under construction--N781DM reserved
Donated
Old 10-08-2019, 07:52 PM
flyboy1963's Avatar
Default ditto - duracell suck!
yep, if you want to ruin something, put in Durahells!
how they stay in business is a testament to mass advertising showing firemen saving people with their flashlites!?!
Energizer will replace the device if their batteries leak. I think we should all write in to Durahell and demand the same! ...and let Costco know they need to switch!
https://www.energizer.ca/about-batte...eaks-guarantee
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 10-08-2019, 08:06 PM
Tag Tag is offline
Default Same Here
I?ve made the switch about a year ago for the same reasons...
Old 10-08-2019, 11:33 PM
gasman gasman is offline
a watery mixture of baking soda and a cotton swab can clean up most battery leaking issues and save the device if it has not been ignored for a long time.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 10-09-2019, 04:43 AM
Ted RV8 Ted RV8 is offline
Have to agree Duracell have become very bad in the past few years. Thinking they?ve changed something in manufacturing as they used to be the best.
Some ELT?s say only approved with specific Duracell?s? What to do?
Before could take the old batteries out of the ELT that I would replace every year regardless of use and use them in flashlights. No longer can, when I put them in a flashlight to use they're dead after six months of sitting. Doesn?t instill confidence that the ELT will work when you need it.
