Of note, this 3 blade Hartzell requires a dampened crank. I understand these are engines with the "6" in the engine suffix.
Questions for the engine pundits.
1) Does this 3 blade prop require a dampened crank for vibration frequency issues?
2) Can a dampened crank engine be used with a standard 2 blade prop such as Hartzell G2YR/N7605W-2X? In other words, would an engine with a dampened crank provide more flexibility in prop selection?
Brian
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
