Old 10-06-2019, 04:16 AM
JoopSJ's Avatar
JoopSJ JoopSJ is offline
Default Request full elec schematic EFII BUS mngr
Anyone with the following setup that is willing to share their full electrical schematic with me?
EFII bus manager
Two batt
Pri and Stby alternator B&C ext regul
b&C volt regulators
G3X
Thank you
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017/2018/2019. . . Done.
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
Old 10-06-2019, 06:55 AM
Mark33's Avatar
Mark33 Mark33 is offline
Hi Joop,
So what information are you looking for? I?m installing the bus manager in my build and for the most part I?m just following the instructions that came with it. There?s a jumper wire inside the unit that needs to be removed...or left in place...depending on if you?re using one (or two) alternators...(I don?t remember which way right off hand).
I?m using two batteries, (one lead acid/one lithium), but only the lead acid one will be used for starting; the lithium is just there for backup power...(I?m only running one alternator so I want a big healthy backup battery in place in the event I loose alternator power).
The main things I like about the bus manager is that it simplifies essential and main bus wiring, it senses low fuel rail pressure and automatically activates the backup fuel pump, and it allows you to mix and match lead acid and lithium battery in your charging system...(which is usually a no no).
Mark H.
RV-7- IO-360, EFII, Whirl Wind C/S, (Built and sold)
RV-4- O-320, Catto three blade, P-Mags (Sold)
RV-8- IO-360, Hartzell C/S (Flying)
RV-7- (Building)
Old 10-06-2019, 08:55 AM
JoopSJ's Avatar
Hi Mark,
Indeed, bus manager simplyfies the wiring and the schematics provided are very clear.
The only thing is that I want to make sure the part ?LEFT? of the bus manager (ALT, SHUNT, ANL, BATT) is wired correctly.
I think even while that is straight forward, I just want to compare my setup to check that I didn?t miss anything.
Eventually I will send my final plan to Robert for verification.
Member EAA
Member AOPA
Old 10-06-2019, 10:23 AM
Mark33's Avatar
I wish that I could be more help with giving you tips or helping you confirm proper installation of your wiring, but my setup will be a little bit different from yours. I?m actually incorporating the new Primary Power System (PPS) from Vertical Power. The functions that you get out of a standard setup using a SHUNT, ANL, etc., are built into the PPS, so like the bus manager, it?s simplifying my wiring. I?m sure Robert will be able to confirm that you have everything wired correctly.
Mark H.
RV-7- (Building)
Old 10-06-2019, 08:49 PM
johnbright's Avatar
johnbright johnbright is offline
Default automatic pump switching
Just be aware of single points of failure.
Some food for thought here, this issue starts at post #56.
John Bright, RV-6A 25088, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDSEFI EM-5-F
Schematic and other electrical related files
Instrument panel CAD jpg images
Construction Photos
Newport News, Va
Old 10-06-2019, 11:39 PM
Mark33's Avatar
Yes, I commented on this thread. For the reason you?re pointing out I?m installing duel relays running in parallel with each other. Each fuel pump will have it?s own relay but will also be able to be powered by the opposite relay. Each fuel pump will also be powered by its own separate circuit breaker.
Mark H.
RV-7- (Building)
Old 10-07-2019, 01:58 AM
JoopSJ's Avatar
@Mark. Could you show me how you wired the second relay? I think that?s a good improvement.
@Jhon, yes I read that thread and your input. I also received a PM from another member pointing me to the same issue. I will receive his settup later.
Does the second relay as indicated by Mark take away your doubts and make the setup acceptable for you.
Member EAA
Member AOPA
Old 10-07-2019, 09:30 AM
Mark33's Avatar
Joop,
I?m going to send a PM to you.
Mark H.
RV-7- (Building)
Old 10-08-2019, 06:55 AM
johnbright's Avatar
Default Bus Manager pump wiring
Originally Posted by JoopSJ View Post
@John, yes I read that thread and your input. I also received a PM from another member pointing me to the same issue. I will receive his settup later.
Hi Joop,
I'm personally planning on a modified Z-14 because I know how to do a failure analysis on it and because the engine will continue to run with the battery contactors off in event of electrical fire in the cockpit.
Some thoughts though on wiring dual pumps with Bus Manager here.
Construction Photos
Newport News, Va
