Originally Posted by Aviacs
How do you apply for a fairing base - are any of the densities trowlable?
The basic plan is to tape a piece of cardboard or typing paper into place to act as a dam, mix/pour the urethane, and stand back while it expands.
Do not try to trowel it, shape it, or guide it in any way, because you'll make a change to local density. Just let it expand and harden, then hack off the excess. A hacksaw blade or a crosscut handsaw works real well, then it's shaped sanding blocks or tubes.
More elaborate parts are possible:
Sometimes a mixed approach (pour foam and block foam) is best.
....cast several sets of urethane rubber rolls for feedworks on woodworking equipment, e.g. for custom apps and a couple customers. After a pour one time, quite a bit was left over, so i saturated some fabric strips cut from polyester knit fabric, and draped it in layers over the side of a PVC pipe. My curiosity was whether it might be useful to cast odd-ball or obsolete MC intake or airbox parts.
Flying that idea about 900 hours now.
http://www.vansairforce.com/communit...t=rubber+ducts
