Old 09-02-2019, 06:20 PM
petehowell's Avatar
Default 2200 Hour Report and Pics
Just back from Big Sky, Teddy Roosevelt NP, and Iowa Trips. Hobbs flipped over 2,200, so I dropped the oil.
Filter and screen had some carbon chunks, and the filter had just a tiny amount of fuzz attracted to a neodymium magnet.
Compressions were 77-78-77-77. Valves looked pretty good!
We are going to continue to run and watch her carefully. Local A&P says many O-320s will go 2,600 hrs+ if they get flown.
O-320/Carb/EI/Mogas/Lots of LOP
#1 -
#3-
#2-
#4-
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 09-02-2019, 07:35 PM
BillL BillL is offline
The combustion side is looking great, I assume the oil sample analyses remaining consistent?
Bill
RV-7
Lord Kelvin:
Old 09-02-2019, 08:22 PM
petehowell's Avatar
Default Analysis
Hi Bill,
I have not pulled a sample for analysis in a bit. I will do that.
Pete
St. Paul, MN
Old 09-02-2019, 09:10 PM
Vlad Vlad is online now
Nice looking valves Pete. Keep it running don't stop. Watch closely do not abuse it. I personally know a motor like yours making double time +.
Old 09-02-2019, 09:28 PM
F1R F1R is offline
Default What Bore scope?
I bet you have been asked before, but those are some very good photos. What bore scope are you using? PC/ android or Iphone /Mac to record them?
long live the 320!
Old 09-03-2019, 09:24 AM
DeeCee 57's Avatar
DeeCee 57 DeeCee 57 is offline
... wild guess, a VA-400 or 800?
Long live all the used engines
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
Old 09-03-2019, 03:14 PM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
Default looks good
keep going and monitor. thanks for the valve documentary.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 09-04-2019, 07:20 AM
rvsxer rvsxer is offline
The pipeline patrol company at our airport runs their O-320's 4,000 hours. No problems at overhaul. They do oil analysis, and all the accessories get changed on a time schedule. I looked at one the other day that had over 3,000 hours on it and it was still getting 12-13 hours out of a quart of oil with the original cylinders. You can imagine how much they fly, and that is probably the main reason the engines are going so far.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 09-30-2019, 01:31 PM
avrojockey's Avatar
avrojockey avrojockey is offline
Forget Lean or green, I'd say those valves are CLEAN of peak
Old 06-29-2020, 02:57 PM
petehowell's Avatar
Default 2300 Hour report!
Not much has changed at 2300 hours. She is still running great.
  • Filter and screen had some carbon chunks, nothing more.
  • Compression #'s were 77-76-77-78 with a warm engine. Valves looked pretty good!
  • As mentioned previously - We are going to continue to run and watch her carefully.
  • Titan O-320/Carb/EI/Mostly Mogas/Lots of LOP
Valve Porn - the cheapo camera was not super sharp this time, but did the trick
Pete
St. Paul, MN
