09-29-2019, 04:53 PM
Gear leg fairings, is clay the best option
I finished my lower gear leg intersection fairings a few months ago, I used the clay method as the plans describe but found it difficult to make smooth. The results turned out pretty good but there was a lot more filling and sanding than I would have liked. Now it is time for the upper fairings, is there something other than clay than can be used and easily shaped? I was thinking maybe plaster or something that can be sanded to its final shape. I also see that vans is offering these fairings now, any experience with these?, are they worth it?
09-29-2019, 05:09 PM
Van's fairings are pretty good as are some of the third party fairings.
But making your own guarantees a good fit. Remember, every 5 minute shortcut you take on making the form or mold will cost you 10x that much time on the back end. If you "roll your own", get your forms perfect before you even think about fiberglass...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
09-29-2019, 07:23 PM
I had to may the fairings for my -9 as Van's as no one provides them and the ones for the -7 don't work on the -9 due to different angles that the gear legs exit the cowl.
(This is for a -9, not a -9A.)
I did use clay and use a lot of water to smooth them down. If the clay is not smooth then the fiberglass won't be either.
It just takes time to smooth them out.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
09-29-2019, 10:12 PM
I’ve used pour in place foam for fairings. There are threads on methods. Pretty easy to shape.
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
09-30-2019, 07:35 AM
I assume you used non-hardening clay.
I found that a little Coleman Fuel on my fingers worked a lot better than water to smooth the clay. Once I figure this out it was fairly straight forward.
Don?t forget to use a couple of coats of hair spray as a release agent.
Carl
09-30-2019, 07:49 AM
3rd Party
I didn't care much for the Van's ones, so I bought the popular 3rd party choice and were pleased with them. I cannot deny that it is probably cheaper to build your own, and yes, this IS a home built....but there are simply some jobs on these planes that simply scream out for "just bite the bullet, buy them, and save yourself a month of grief"....This is one of them, in my opinion...YMMV.
Brian K. Morrow
DuBois,Il
N433BC RV-7A Flying
RV-12is EMP in progress!..Official Repeat Offender
"Maintain thy airspeed...Lest the earth arise and smite thee..."
09-30-2019, 08:40 AM
I've abandoned clay. 4lb density pour foam is wonderful.
Dan Horton
RV-8 SS
Barrett IO-390
09-30-2019, 09:45 AM
What do you think about great stuff , the foam that is available at Home Depot?
09-30-2019, 11:20 AM
Dan, can you give us the link to that?
Dave
09-30-2019, 11:24 AM
It depends on what he is building, aftermarket fairings may not be available.
Bill R.
SC86 - Easley, SC
