Old 09-26-2019, 12:35 PM
Walt's Avatar
Walt Walt is online now
My CHT's rarely reach 350 even with the new HC IO370 in Texas..
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 09-28-2019, 09:50 AM
DennisRhodes DennisRhodes is offline
I always had difficulty in removing the lower cowl because of the lower cowl inlet baffles which were rivet on at the inlets. The dimensions caused the lower cowl to hit the back of the spinner plate before it would drop down. I removed the riveted on seals and replaced with a removable plate and seal for each side. Each attaches with three screws after the lower cowl is installed. This eliminate the clearance problem and works well. I believe the removable seals allow for more overlap and better seal to the upper than before. Ignore the 1/8 rivet holes where the old baffle was attached at least for now. I like it. Will work on the link later today, thanks
Try this one !! If you notice right pic you can see where the spinner has scratched all the paint off the lower cowl
https://photos.app.goo.gl/Kwx3hDNC4WLfDBcF9
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 09-28-2019, 11:43 AM
TShort TShort is offline
The photo link doesn?t work for me...
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 09-28-2019, 12:32 PM
DanH's Avatar
DanH DanH is offline
Note the nice, even wear marks on Walt's seals. There are a few leaky spots, but not many.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-28-2019, 02:28 PM
rv8ch's Avatar
rv8ch rv8ch is online now
Default removeable lower cowl baffle seal
Originally Posted by DennisRhodes View Post
... I removed the riveted on seals and replaced with a removable plate and seal for each side. Each attaches with three screws after the lower cowl is installed. ...
This seems like a good idea - do you have any photos of the inside?
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 09-28-2019, 03:21 PM
No, but I might be able to get you a pic of the baffle as removed. Comes out with 3 screws. The baffle mtl is riveted to an alumin plate and has three random located nut plates attached . So the baffle mtl is sandwiched between the alumn and the cowl when attached. Bottom side would show only alumn and nutplates.
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 09-28-2019, 03:28 PM
RV10Pilot RV10Pilot is offline
Old 09-28-2019, 04:03 PM
here is how it is done on the 10
Old 09-28-2019, 04:52 PM
Thanks for adding the pic, I 've never been able to do that!! Didnt know that was the RV 10 method but it also works well on my 9 and yes aside from nutplates vs a AN nut, thats exactly same. Having the nutplates allow me to remove the seal before the cowl comes off.
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 09-28-2019, 08:08 PM
fl-mike's Avatar
fl-mike fl-mike is offline
That big 'ol hole behind #3 can't be helping!
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
