Originally Posted by Captain Avgas
.....I would upgrade from DP40 to a Boeing spec BMS10-11 product (Akzo have one)..........
Akzo is truly tough stuff. I like it because you can shoot a part and in less than an hour, the part is dry enough to work with. Here's something no rattle can primer can claim. When Akzo is fully cured, you can wipe it down with MEK over and over and over and the most you will do is lighten it. I have never found
any rattle can primer that can hold up to a thorough and periodic wipe down with MEK, which the floor of my 6A can attest too.
Using the little spray gun fitted with a 35mm film canister, I shot the entire -8 fuselage interior....sometimes as few as one or two pieces at a time using Akzo. It is very easy to mix a small amount, frequently I mix less than 4 oz. at a time using small dixie cups as disposable measuring devices and waste is kept to a minimum.
My idea of surface prep is nothing more than a wash in mild soapy water using a scotchbrite pad for light scrubbing, then rinse and dry. Larger parts were done in the bathtub. Really large parts are done outside with a bucket of soapy water and a garden hose. Prior to applying the primer, I wipe down the part surface with MEK which as you know evaporates almost immediately.
The stuff dries like porcelain.
