Old 09-17-2019, 11:05 AM
avrojockey's Avatar
avrojockey avrojockey is offline
Default Is this an Exhaust Leak?
O-320-A1A EXHAUST PICTURE
Referencing linked picture above...What say ye concerning the rust color on the head near the exhaust flange and around the plug well?
It looks to me like a exhaust leak but isn't the typical white color. The other thing I notice is the flange studs...doesn't look like those nuts have come off in awhile which means the exhaust hasn't been removed for inspection.
Old 09-17-2019, 11:32 AM
airguy's Avatar
airguy airguy is offline
Possible crack in the head between the exhaust port and spark plug hole?
Old 09-17-2019, 12:43 PM
xblueh2o xblueh2o is offline
Easy enough to test. Pull the plug and do a compression check.
If it is a leak/crack it will show itself instantly.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 09-17-2019, 12:47 PM
lr172 lr172 is offline
Typical signs of exhaust leak are a matte, dark black staining/coating. Rust is something different.
Old 09-17-2019, 05:45 PM
fl-mike's Avatar
fl-mike fl-mike is offline
What is above the cylinder in that area?
Mike W
Venice, FL
N164WM
Old 09-17-2019, 07:40 PM
Ash Ash is offline
Not necessarily true. If the crack is between the exhaust valve and the exhaust manifold, a compression check will not reveal a crack/leak in that area. We found that this past week on our #2 cylinder on our Warrior. It compression tested at 76lbs, but a cracked cylinder in the exhaust port was found.
Old 09-18-2019, 06:41 AM
rvsxer rvsxer is offline
Every exhaust leak I've seen showed as a white or light tan coating. If it's black you are too rich at idle.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 09-18-2019, 09:09 AM
avrojockey's Avatar
There's nothing mounted on or above the head that would be causing the discoloration.
Old 09-18-2019, 09:23 AM
snopercod's Avatar
The source of those rust-colored deposits has to be steel, so that pretty much narrows down the source. If it were my plane, I would suspect that exhaust gasket first. Good luck breaking that exhaust nut free
(2020 dues paid)
Old 09-18-2019, 10:39 AM
fl-mike's Avatar
what color is your baffle material?
Mike W
Venice, FL
N164WM
